Pic Request External Oiling #452762
08/28/09 07:35 PM
08/28/09 07:35 PM
U.S.
moparniac Offline OP
U.S.
Can someone post up a pic of how there single line external oiling is hooked up / routed ??? I have a 71 Dart.... looks tight in there......
Mopar Performance
Re: Pic Request External Oiling [Re: moparniac] #452763
08/28/09 08:32 PM
08/28/09 08:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Have fun some take line comes out the back of the cap and some out the top (er bottom??)
Re: Pic Request External Oiling [Re: Dodgem] #452764
08/28/09 08:34 PM
08/28/09 08:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You can but the conversion type use stock HV pump needs longer drive gear I have both for sale
Re: Pic Request External Oiling [Re: Dodgem] #452765
08/28/09 08:35 PM
08/28/09 08:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
How my one line goes back
Re: Pic Request External Oiling [Re: Dodgem] #452766
08/28/09 08:37 PM
08/28/09 08:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
on mine strait out the back of cap not an option because of motor mount!! when I go e ears it may be??
Re: Pic Request External Oiling [Re: moparniac] #452767
08/28/09 08:46 PM
08/28/09 08:46 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
On my 69 Dart I could never seem to get it to fit with stock mounts I even ground away at the steering box mount, one of the many reason I went with a motor plate.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Pic Request External Oiling [Re: Dodgem] #452768
08/28/09 09:01 PM
08/28/09 09:01 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If you use a aftermarket block, it makes it slick, and you dont need that leak prone milodon center section. You just need the oil pump cover with a single fitting for a single line. This lets you use your standard length oil pump shaft and gear setup. Then on a duel line setup One line runs from the block port (near timing chain cover) to the pickup. and you already have the other coming from the oil pump cover. This duel line system is great and feeds about any engine. Its not expensive, cause all your out is the pump cover, and the lines/fittings, but this is on the aftermarket blocks.
So If I was going to use a single line system with a stock block....
I would just by the pump cover, probably by it separate from Milodon, or Muscle Motors has a nice one also. Use a stock HV oil pump, use your current bronze gear, which that save a bunch of money not needing to buy another.
Buy the static pickup from 440Source. Its a large pickup. And install it in a standard pan.
The Indy pump cover is nice but over priced IMO, I ran it, and it was a nice piece...but was like $225 just for the pump cover.
Hemi block oil port (World Block)
Indy Wedge Block.
Not a very good picture
Re: Pic Request External Oiling [Re: Dodgem] #452769
08/29/09 12:00 PM
08/29/09 12:00 PM
U.S.
U.S.
What type of pump is that... its slick..... So I guess going with that pump it will work...
Mopar Performance
Re: Pic Request External Oiling [Re: moparniac] #452770
08/29/09 12:01 PM
08/29/09 12:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You may want to buy a pump body or sandwich pick up with the line that loops out the front that will allow you to snake it back along the side of the oil pan like my front line!
Re: Pic Request External Oiling [Re: Dodgem] #452771
08/29/09 12:12 PM
08/29/09 12:12 PM
U.S.
U.S.
It looks to me like the front line hookup is the way to go with no clearance issues also...
Mopar Performance
Re: Pic Request External Oiling [Re: Dodgem] #452772
08/29/09 12:29 PM
08/29/09 12:29 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you can buy just this the line and a single line pick up PN 21350 it can be used to convert a standard HV pump to external pick up
Re: Pic Request External Oiling [Re: Dodgem] #452773
08/29/09 12:30 PM
08/29/09 12:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
the line
Re: Pic Request External Oiling [Re: moparniac] #452774
08/29/09 12:31 PM
08/29/09 12:31 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Front line would be better.. I have a dual line and had to cut some of the steering box and re brace it to clear the line.. I can take some pictures if that will help ya..
Re: Pic Request External Oiling [Re: Dodgem] #452775
08/29/09 12:32 PM
08/29/09 12:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
then your pick up of choice
Re: Pic Request External Oiling [Re: Dodgem] #452776
08/29/09 12:52 PM
08/29/09 12:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here is the only one I can find...Dual line from the Hemi.
Bottom side sort of, oh yeah ignore the hole
Re: Pic Request External Oiling [Re: moparniac] #452777
08/29/09 01:15 PM
08/29/09 01:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
milidon pump
Re: Pic Request External Oiling [Re: moparniac] #452778
08/29/09 01:28 PM
08/29/09 01:28 PM
AndyF Offline
AndyF  Offline
If you have the new World block you can avoid that problem. The World block is drilled and tapped on the front for an external oil input. Then you can use a standard pump and cover and avoid the clearance issues.
Re: Pic Request External Oiling [Re: Al_Alguire] #452779
08/29/09 03:41 PM
08/29/09 03:41 PM
U.S.
U.S.
Al after looking at my car the oil line will route the way your is in that pic.... Is that a milodon pump also
Mopar Performance
Re: Pic Request External Oiling [Re: moparniac] #452780
08/29/09 11:11 PM
08/29/09 11:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
this is a stock pump sandwiched between that plate and a milidon cap/cover
Re: Pic Request External Oiling [Re: Dodgem] #452781
08/29/09 11:14 PM
08/29/09 11:14 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
PN 21350 on a stock pump!
