Re: Pic Request External Oiling
[Re: Dodgem]
#452764
08/28/09 08:34 PM
08/28/09 08:34 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You can but the conversion type use stock HV pump needs longer drive gear I have both for sale
[Re: Dodgem]
#452768
08/28/09 09:01 PM
08/28/09 09:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
If you use a aftermarket block, it makes it slick, and you dont need that leak prone milodon center section. You just need the oil pump cover with a single fitting for a single line. This lets you use your standard length oil pump shaft and gear setup. Then on a duel line setup One line runs from the block port (near timing chain cover) to the pickup. and you already have the other coming from the oil pump cover. This duel line system is great and feeds about any engine. Its not expensive, cause all your out is the pump cover, and the lines/fittings, but this is on the aftermarket blocks. So If I was going to use a single line system with a stock block.... I would just by the pump cover, probably by it separate from Milodon, or Muscle Motors has a nice one also. Use a stock HV oil pump, use your current bronze gear, which that save a bunch of money not needing to buy another. Buy the static pickup from 440Source. Its a large pickup. And install it in a standard pan. The Indy pump cover is nice but over priced IMO, I ran it, and it was a nice piece...but was like $225 just for the pump cover. Hemi block oil port (World Block) Indy Wedge Block. Not a very good picture
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparniac]
#452777
08/29/09 01:15 PM
08/29/09 01:15 PM
Dodgem
Ontario, Canada
on mine strait out the back of cap not an option because of motor mount!! when I go e ears it may be??
What type of pump is that... its slick..... So I guess going with that pump it will work...
milidon pump
[Re: moparniac]
#452780
08/29/09 11:11 PM
08/29/09 11:11 PM
Dodgem
Ontario, Canada
this is a stock pump sandwiched between that plate and a milidon cap/cover
