Window net? #452735
08/28/09 07:09 PM
08/28/09 07:09 PM
east coast
Otherlane Offline OP
east coast
What do you guys use to latch your windown net to a no funny cage car? what windown do you guys also? like to see pics if possible.thanks
Re: Window net? [Re: Otherlane] #452736
08/28/09 08:19 PM
08/28/09 08:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought a kit from here
http://www.rjsracing.com/windownets.html
Plus they will make custom shape nets if you need it,
just make a card board template
Re: Window net? [Re: MR_P_BODY] #452737
08/29/09 06:58 AM
08/29/09 06:58 AM
east coast
east coast
87 people looked at this post and no one has window nets? Like to see some pics of yours if i can
Re: Window net? [Re: Otherlane] #452738
08/29/09 08:17 AM
08/29/09 08:17 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I used the kit that Mr.P Body posted a link to, I use the one with the angle bottom as it fit better in my window opening.
Re: Window net? [Re: DusterKid] #452739
08/29/09 08:26 AM
08/29/09 08:26 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
I don't have a funny car cage, but I made my own mount its basicly a L shaped piece that hinges on one end and has a pull up stop on the other . I'll get over to the shop this evening anf try to take some pic's
Re: Window net? [Re: hemiparts] #452740
08/29/09 08:57 AM
08/29/09 08:57 AM
east coast
east coast
Ok just dont know if i want the seat belt latch.want to see what if looks like on other peoples cars
Re: Window net? [Re: Otherlane] #452741
08/29/09 10:07 AM
08/29/09 10:07 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Used seat belt latches in many, one thing to consider is the friggen tab welded to the bar. If its a tight squeeze in you will fight it.
Old man recently went and put in old hardware from race belts, works much better in his car.
Re: Window net? [Re: Otherlane] #452742
08/30/09 09:56 AM
08/30/09 09:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have no pictures since mine isn't done yet. I've checked out a few different types. I'm not a big fan of the bulky seat belt buckle. My buddys new S/S Mustang uses a spring loaded ball stud from carb linkage to latch the rod. My last car used a quick pin thru a pair of tabs. Both rods are vertical on my friends GTX. The rear is rod vertical along the main hoop. The front rod pivots up from the door bar stretching the net forward to back. That way there are no cables needed to attach the rods.
Doug
Re: Window net? [Re: dvw] #452743
08/30/09 11:26 AM
08/30/09 11:26 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
I got tired of raking my back across the seat belt tab so I redid mine when I added the FC cage. Sounds like mine is the same as Dougs. Its a spring loaded ball joint linkage. I also made a cardboard template and had RJS custom make it. Will go out to the garage and take a couple pics for you.
http://www.mcmaster.com/catalog/115/gfx/small/6058kp4s.gif
Re: Window net? [Re: TS3303] #452744
08/30/09 11:35 AM
08/30/09 11:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is attached with a seat belt tab as well. It is far enough forward that I have not hit my head on it ever. I dont have any pics though. My net is a Stroud.
Re: Window net? [Re: Al_Alguire] #452745
08/30/09 01:00 PM
08/30/09 01:00 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I believe most cars do use a type of seat belt catch. I also believe that in an emergency most people that would attempt to help remove you from a car would be looking for a seat belt release. Some of the other systems used the person would never be able to release the catch to assist getting you out of the car. Be safe and use the typical release. Some of them that come in kits are not huge seat belt size units but are very easy to use and do not get in the way.
Re: Window net? [Re: Blucuda413] #452746
08/30/09 02:32 PM
08/30/09 02:32 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
battery was low so pics are blurry, will retake after batteries get charged.
Re: Window net? [Re: TS3303] #452747
08/30/09 02:33 PM
08/30/09 02:33 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
2
Re: Window net? [Re: TS3303] #452748
08/30/09 06:57 PM
08/30/09 06:57 PM
east coast
east coast
TS3033
