Trapped air??? #452403
08/28/09 09:44 AM
08/28/09 09:44 AM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Okay dad put a plate over the front opening, between the grill and the core support to cover the hole many years ago, and I'm woundering if maybe that is trapping air and slowing the car down.. any thoughts.. In the picture you can see it bottom left and runs the lenght of the front end..
Re: Trapped air??? [Re: 70dusterjohn] #452404
08/28/09 12:02 PM
08/28/09 12:02 PM
Have you run the car since adding the plate? If so what are the results on the MPH? I think it is a good idea based on past experiences with three different Dusters, it forces the air to go thru the radiator and the holes in the core support instead of blowing over the top of the core support into the engine compartment forcing the front edge of the hood up trying to rip it off
Re: Trapped air??? [Re: Cab_Burge] #452405
08/28/09 12:07 PM
08/28/09 12:07 PM
Deerfield, Ohio
Deerfield, Ohio
Its never not had it on... as as far back as I can remember its been there.. Dad bought the car in 73 and has been in the family since. But has always had that plate there...
Re: Trapped air??? [Re: 70dusterjohn] #452406
08/28/09 12:28 PM
08/28/09 12:28 PM
Deerfield, Ohio
Deerfield, Ohio
And I really don't think that it helps with the hood cause at 135 it still wants to come off.
Re: Trapped air??? [Re: 70dusterjohn] #452407
08/28/09 12:40 PM
08/28/09 12:40 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
i dont think that is slowing anything down. Is that a cool can ? What hood and scoop ?
Re: Trapped air??? [Re: cudabunch] #452408
08/28/09 12:50 PM
08/28/09 12:50 PM
Deerfield, Ohio
Deerfield, Ohio
yep that sure is.. It's been there forever.. I have changed the fuel system on the car and I'm running a return line. Had vapor lock problems before, and not a lot of money, and It was free.
Its a fiberglass 6inch cowl hood..
Re: Trapped air??? [Re: 70dusterjohn] #452409
08/28/09 01:00 PM
08/28/09 01:00 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Put some rubber molding between the radiator support and the hood to stop the air.
Re: Trapped air??? [Re: 70dusterjohn] #452410
08/28/09 05:58 PM
08/28/09 05:58 PM
Deerfield, Ohio
Deerfield, Ohio
Anyone else... Should I leave it or pull it and try it on a run or two...
night time guys..
Re: Trapped air??? [Re: 70dusterjohn] #452411
08/28/09 10:40 PM
08/28/09 10:40 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'd vote leave it in place, but a very easy test, likely to give negative results, make a run with the hood off.
