Trouble removing horn trim ring??? #452270
08/28/09 12:23 AM
08/28/09 12:23 AM
Lawrence, KS
coledavis01 Offline OP
Lawrence, KS
I feel like a moron posting this but here goes.
Is there a trick to removing a horn trim ring? (69 coronet) other than "turn counterclockwise" as the manual states?? Tried pushing and pulling while doing this w/ no luck. Dont want to scratch the wheel up but I am beginning to lose patience.
Thanks!
Cole
Re: Trouble removing horn trim ring??? [Re: coledavis01] #452271
08/28/09 12:27 AM
08/28/09 12:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
See that Dodge emblem it the middle of the steering wheel? use a small screwdriver, slip it under an edge & carefully pry that part out... then you'll know whats next...
Re: Trouble removing horn trim ring??? [Re: 1_WILD_RT] #452272
08/28/09 12:32 AM
08/28/09 12:32 AM
Lawrence, KS
Lawrence, KS
They need a smiley smacking itself in the head with a hammer graphic to insert here!
Thank you very much 1 Wild RT, I can rest easy now.
Cole
Re: Trouble removing horn trim ring??? [Re: coledavis01] #452273
08/28/09 12:34 AM
08/28/09 12:34 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If the manual was correct you'd be done by now...
