Re: Who Has used AMD or GoodMark Full floors Floors
[Re: 340SIX]
#451993
08/28/09 10:15 PM
08/28/09 10:15 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
kevin, go with the amd stuff for a couple of reasons.. first, goodmark has sold us in the hobby crap for many years the ONLY reason they have gottin better and stepped up thier game is because if they didn't they would be put out of buisness by amd,not because they want to make a better product. i refuse to use them on that reason alone. i've seen alot of amd products up close personally and have used a few and they get the from me. amd all the way
[Re: cataclysm80]
#451994
08/28/09 10:21 PM
08/28/09 10:21 PM
Posts: 4,165 Florida
cataclysm80
Front floor pans are the same on Barracuda & Challenger. The only difference would be the year, 70 vs. later. (If you're getting a used floor from a parts car, you'd also want to consider manual vs auto trans, & console vs no console.)
Rear floor pans have the 70 vs. later difference, + they are also different on Barracuda vs. Challenger. The Challenger has a two inch longer wheelbase. On the bottom of the car, the Challengers extra two inches are a flat strip of metal which is at the leading edge of the rear floor pan. Challengers also have an extra body plug on each side of the car within that 2 inch flat section.
To put Challenger rear floor pans in a Barracuda, you'd need to cut two inches off.
To put Barracuda rear floor pans in a Challenger, you'd have to weld in an extra two inches across the front.
(just a note: On the side of a Challenger the extra two inches are between the rear wheelwell & the door. On the top of a Challenger the extra two inches are mostly in the C pillar, but the whole roof is different, so it's hard to compare.)
Tav
[Re: cataclysm80]
#451996
08/28/09 11:59 PM
08/28/09 11:59 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I'm pretty sure that the new floor pan will be just the floor pan. There are several things you'll need to move over onto the new one from your original.
Bucket seat reinforcements (big square plates around seat holes)
Speedo cable retaining tab (below drivers feet)
Dimmer switch holes.
console / shifter brackets. (be careful to get these in the right spot!)
And on the rear floor pans... Seat belt reinforcements (rectangular plate threaded for seat belt bolt)
Parking Brake Cable Guide
Tav
thats why I was asking for a realy clean underside pic with whats what. I have all of that but may be located in anther place on a differant year car. The AMD rears have the seat belt reinforcements and the 70 lip. The front pans have them as well but I have everything just unsure of locations for a 1970 car. I have plenty of time to get a good pic or 2 with locations of everything. I saved a few pics of cars on here on a rotissire{sp?}
[Re: cataclysm80]
#452002
08/29/09 02:01 AM
08/29/09 02:01 AM
340SIX
I hope that helps.
Need anything else?
Tav
Thanks I will save them all.
