727 trans how many quarts? #451612
08/27/09 09:37 AM
08/27/09 09:37 AM
Central Vermont
DUSTERB'D Offline OP
Central Vermont
I have a 727 with the deep steel Mopar pan, how many quarts of fluid are you supposed to run? Thanks, MSC
Re: 727 trans how many quarts? [Re: DUSTERB'D] #451613
08/27/09 09:55 AM
08/27/09 09:55 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would put about 5 quarts in and run till warmed up. Run through the gears and check in nuetral and fill to the full mark. Full level remains constant even with a deep pan.
Re: 727 trans how many quarts? [Re: DUSTERB'D] #451614
08/27/09 10:38 AM
08/27/09 10:38 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
DEPENDS on a lot of things ...size of the converter, the size of the trans cooler, and the depth of the pan. Now running the level the same NO MATTER what depth the pan is ? .. is a personal choice. I have a big-time-deep Fairbanks pan(5 quarts more) on my stuff and I run the level WAY lower .. to prevent ATF and windage probs.
Re: 727 trans how many quarts? [Re: dOOc] #451615
08/27/09 11:27 AM
08/27/09 11:27 AM
Central Vermont
Central Vermont
I have a 10" turbo action converter, and a cooler roughly 14" by 6", MSC
Re: 727 trans how many quarts? [Re: dOOc] #451616
08/27/09 12:34 PM
08/27/09 12:34 PM
Upper Midwest
Upper Midwest
Full is like I said full. I do run mine at about half way between the add and the full mark. I like the added fluid volume as it helps the transmission fluid stay slightly cooler.
