Crane R280-.4468-08 Roller Cam Card Info? #451025
08/26/09 05:58 PM
08/26/09 05:58 PM
Indiana
Cuda_Mike Offline OP
Indiana
Does anyone have the cam card info on this old cam? Sold by Direct Connection many moons ago...
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451026
08/26/09 06:03 PM
08/26/09 06:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
That should be 280 degrees at .050, .4468 lobe lift ground on 108 lobe sepperation angle on both lobes if I'm inturpreting (SP?) those numbers correctly
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cab_Burge] #451027
08/26/09 06:09 PM
08/26/09 06:09 PM
Indiana
Indiana
That's right Cab, just hoping for the rest of the install numbers. I ran one of these 20 years ago, and don't remember the details.
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451028
08/26/09 06:12 PM
08/26/09 06:12 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Crane cam chart, the one highlighted is not yours, i reckon yours might be R280 450.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: deaks] #451029
08/26/09 06:57 PM
08/26/09 06:57 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Deaks, don't think U highlited the right cam. Don't think I see it here. Cab's comments are right, 670 lift[1.5]. We installed it at 103.5 and set lash at .026 500" 440-1 motor. Great sounding cam, still have it.
i
The little old lady from Pasadena is back!
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Barnstorm] #451030
08/26/09 07:13 PM
08/26/09 07:13 PM
Indiana
Indiana
Bill, What compression are you running and how's the e.t.? I'm going to use my old Stage VI's on mine...so it will be considerably slower.
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451031
08/26/09 07:36 PM
08/26/09 07:36 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Ran that cam til 03. Motor 500" 440-1 14-1 1150 dom on 440=3 intake made 766hp at 7000, 670 tq at 5200. Ran 9.70's. Great rebuild in 03 by Lynn Balek, changed little xcept now Comp Cam picked up 60hp and 30#tq.
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: deaks] #451032
08/29/09 12:57 PM
08/29/09 12:57 PM
south williamsport pa
3
383bart Offline
383bart  Offline
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: 383bart] #451033
07/11/13 07:30 PM
07/11/13 07:30 PM
Indiana
Indiana
New question on this old subject, I've been running this cam installed at 102* thinking of retarding it to 106*-110* any predictions on the result of this change?
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451034
07/11/13 08:11 PM
07/11/13 08:11 PM
Indiana
Indiana
Barnstorm, Hey Bill, what were the specs on the Comp Cam that picked up 60 hp?
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451035
07/12/13 02:47 PM
07/12/13 02:47 PM
Indiana
Indiana
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451036
07/12/13 04:13 PM
07/12/13 04:13 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
as to Comp Cam #??
Re: Crane R280-.4468-08 Roller Cam Card Info? [Re: Cuda_Mike] #451037
07/12/13 04:23 PM
07/12/13 04:23 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Intake..duration 294duration@.050..lift .741 Exhaust..duration 281@ .050...lift .693 both with 1.5 rockers. 110 centerline no cam advance. Seems to run a little better with lash .010 tighter. Car is a tenth or two quicker but 60fts a little better. No change in MPH. Sounds nothing like the old Crane [best ever]. Running Comp 948 springs and will pull to 7600 now.
