3.73 or 4.10 #450881
08/26/09 02:47 PM
08/26/09 02:47 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
on the fence what do you think
490 ci cnc standard port victors 10.8 cp m1 2 circuit 1050 cam 263int 269ext 108 408 lobe both sides 2" primary 3.5" 3" x pipe borlas. 9" ATI 4200 3450 a body cal tracs 325/50 MT street radial 28" want to drive on street. Bracket race 1 time a month.
If it was your heep what would you run?
Re: 3.73 or 4.10 [Re: 71Pan] #450882
08/26/09 02:58 PM
08/26/09 02:58 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
... want to drive on street. Bracket race 1 time a month.
3.73
I run 4.10's but I race more often and only occasionally street drive.
I feel safer on the track than I do on the street...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: 3.73 or 4.10 [Re: 71Pan] #450883
08/26/09 03:01 PM
08/26/09 03:01 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Is this an 8 3/4 car ?
Re: 3.73 or 4.10 [Re: BBLM23] #450884
08/26/09 03:02 PM
08/26/09 03:02 PM
If it were mine 3.91's...
Re: 3.73 or 4.10 #450885
08/26/09 03:06 PM
08/26/09 03:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
sounds like a pretty stout mill to drive around.
If it were me, i would set it up for the track, and put up with the few hundred rpm difference on the street you are taking about with your gear choice. It isnt gonna get 30mpg no matter the gear choice, Why not make it run the best it can, and just throw a hair more fuel in it on the street
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 3.73 or 4.10 [Re: B3422W5] #450886
08/26/09 03:18 PM
08/26/09 03:18 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
My combo is almost identical to yours, and I'm going with 4.10's. My car is not weighed yet, but should be around 36-3700lb with me, 511, 10.5-1, cnc stealths, 262@.050 solid flat tappet, holley sd intake, 950 quickfuel, 9.5" PTC 4200, 2" TTI's, 3" x pipe and ultra flos and 295/65 drag radials. I don't plan on any cross country trips, but I can still cruise 50-100 miles if I want without much hassle. I don't mind cruising in the granny lane if necessary. I would rather be better prepared at the track BTW, did you dyno your engine?
2 kids and a dog
Re: 3.73 or 4.10 [Re: TonyS451] #450887
08/26/09 03:21 PM
08/26/09 03:21 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Dana 60
Re: 3.73 or 4.10 [Re: 71Pan] #450888
08/26/09 05:53 PM
08/26/09 05:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
In an A-body with that combo you could get away with 3.73's since you plan to drive it alot. You can always play with tire sizes also. I would say 4.10's but unless you modify the wheelwell you cant get a very tall tire on an A-body. I run 4.30's but I dont have near the power you do so I need the gear and I use a 30" tall tire on my B-body to help keep the RPM's down. My son uses 3.91's in his Dart and he cant fit no taller then a 28" tire which still rubs some. If you cant fit taller then a 28" tire I would go with the 3.73's as you will have enough power at the track to get away with them. Ron
Re: 3.73 or 4.10 [Re: 71Pan] #450889
08/26/09 08:02 PM
08/26/09 08:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I drive several miles at a time w/4.11`s but I run the hoosier qtp 29" tires so you`ll have a bit less circumference so maybe high 3`s will give the best of both worlds. By the way, it`s NEVER too radical to drive on the street........my small 470 has an 8" 5000 vert, 4.11`s, dominator and a solid roller w/.680-660 lift and 275-280 duration @.050 and idles like a kitten and cruises effortlessly.
Re: 3.73 or 4.10 [Re: Thumperdart] #450890
08/26/09 08:23 PM
08/26/09 08:23 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
4.10 are going in thanx guys
