tightening crank bolt?
#450812
08/26/09 01:54 PM
08/26/09 01:54 PM
Posts: 761 KY
juicedcuda
KY
The motor is already in the car, driveshaft, etc. What is the best way to torque the crank bolt?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: tightening crank bolt?
[Re: juicedcuda]
#450813
08/26/09 01:58 PM
08/26/09 01:58 PM
Posts: 31,085 Oregon
AndyF
Mancini Racing makes an inexpensive tool that bolts to the damper and provides a place to install a 1/2 breaker bar. Then you can hold the damper with a long breaker bar and torque the bolt with a torque wrench. Look in their tool section at www.manciniracing.com
[Re: AndyF]
#450814
08/26/09 02:05 PM
08/26/09 02:05 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
If you have a good air compressor, and a strong 1/2 impact, just add some red LockTight and hammer away...I have been doing this for years, and years with not a single problem, or loose bolt.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#450815
08/26/09 03:49 PM
08/26/09 03:49 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
AMEN _ Not going to knock that method as it is the same one I have used for many a year gone by and I've never had a problem with it either. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MoparforLife]
#450817
08/26/09 07:59 PM
08/26/09 07:59 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
x2. Impacts lend themselves to this VERY well. I use a good 1/2" too, but I use Loctite blue, and never had a problem either.
[Re: juicedcuda]
#450818
08/27/09 01:00 AM
08/27/09 01:00 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
remove one of the spark plugs(whichever one is the best in your car to get to) and put air pressure in it to hold the piston down and use a torque wrench to torque the bolt to 150+ Lbs ![](/ubbthreads/images/graemlins/thumbs.gif) if it is a stick shift car put it in reverse and have someone hold the foot brake down and go for it ![](/ubbthreads/images/graemlins/thumbs.gif)
