Re: newbie blues
[Re: wingman]
#449772
08/25/09 09:37 PM
08/25/09 09:37 PM
RapidRobert
get the valley pan gasket w the holes blocked. Trust us on this one.
Re: newbie blues
[Re: 71scamp440]
#449773
08/25/09 09:47 PM
08/25/09 09:47 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
im having a case of the newbie blues. im putting a set of 915 heads on a 400 block. all was going well until i got to the intake. my gaskets dont fit properly. i think its leaving the heat cross over open? do i need a special intake with these heads. both the 400 intake and a 440 intake fit fine with the exception of this hole being wide open. what do i need to do to solve this problem?
Either I'm reading your post wrong but the 440 intake will not fit the 400 block.If you are refering to gaskets,then you're ok.
Re: newbie blues
[Re: 1_WILD_RT]
#449776
08/26/09 06:59 AM
08/26/09 06:59 AM
Posts: 531 Virginia
JimG
Virginia
Yeah, Felpro makes one with it blocked, I'll see if I can find the number... FWIW some guys don't like blocking the heat, in the old days I didn't either, but the fuel has gotten to the point you've gotta do something..
Felpro #1214
http://www.summitracing.com/parts/FPP-1214/
Have you guys had problems with the "blocked" portion of the gasket burning through?
I never tried the FelPro, but I had a Mr. Gasket burn through once. Now, I use .030" stainless steel shim stock in that area, even if the gasket is already blocked. I had read that only stainless steel will survive in that environment, and the burned through gasket seemed to confirm that.
Perhaps I'm needlessly going overboard; I'd like to hear your experiences.
Thanks!
Re: newbie blues
[Re: Mr.Yuck]
#449781
08/26/09 09:21 AM
08/26/09 09:21 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
nothing much to add here from me! block it, leave it open...it's your choice. to help you decide--some theory behind it! the reason it was there originally, was because these cars were driven year round...or at least, engineered to drive year round. that's why the carbs have chokes, the exhaust has those little flapper valves and the intakes are heated with exhaust gasses. the passenger side "flapper valve" thingy was shut when the engine was cold. this blocked the exhaust (not entirely though) and made it go through that port, through the intake, and out the driver side exhaust. this was to heat up the intake, and to help the fuel atomize, or stay atomized as it passed through the intake, as well as simply warm it up to make it easier to burn. as the engine warmed up, your choke would open up from engine heat, and that flapper valve would also open up, allowing the exhaust an easier shot at going out instead of through the cross over (but, some will still go through it even at full operating temps) today's cars are usually NOT driven year round, and some semblance of performance is desired from them. for maximum performance you want a free flowing exhaust, free flowing intake, and a COLD air/fuel mix coming into the engine because colder air is more dense, and has more O2 to burn, making more power...thats why Cold Air Intakes are so popular...even if they only provide you with 2 or 3 hp. (they all advertise 15-20 though! some do, some dont!) so...ask yourself, is this a summer only vehicle? or will it be used year round? mine is a summer only toy, so my cross over is blocked, and the exhaust is free from any "flapper valve" (sorry, I don't know what it was actually called), and my Carb does NOT have a choke. It really doesn't like to start when it's 45 degrees or less outside, and even when it's 85, I gotta sit there and hold it at 1500-2000 rpms for a few minutes until it warms up enough to idle without stalling. but once warmed up, it idles great, and hot starts are NEVER a problem. now you have the information to make the decision on your own, instead of just counting up how many people have said "I have mine open" compared to how many said "I have mine closed"
**Photobucket sucks**
Re: newbie blues
[Re: 70Cuda383]
#449782
08/26/09 03:00 PM
08/26/09 03:00 PM
Posts: 417 jamestown, ny
71scamp440
Hinged
Hinged
jamestown, ny
thanks 70 cuda. i think im going to leave mine open for now. in N.Y where i live 45 degrees can happen in the middle of summer, so i better leave it open. but then again im gonna run a manual choke so it doesnt matter either way i guess. 6 of one and a half dozen of another.
71 scamp
big block with 915 heads
727 trans
Re: newbie blues
[Re: 71scamp440]
#449784
08/26/09 05:18 PM
08/26/09 05:18 PM
70Cuda383
Marysville, O-H-I-O
yea...not sure it matters...the choke WILL make cold starts easier. but, that is countered by the air flow restriction the choke horn makes.
no choke means more airflow into the carb... but if you're running the heat cross over, then it's going to be hot air!
at one point, I had an edelbrock carb with electric choke on my truck, with the heat cross over blocked, and it would fire off almost immediately, sit on the high idle cam for 15-20 seconds, blip the throttle, and it would idle like it had been running for 30 minutes!
I would consider a choke with blocked off cross over before I would consider no choke with it open.
once it's warmed up, you don't really need the heat cross over, and a cold start...there's no heat in there to help out anyway! that's where the choke helps out!
