727 shifts late / lokar kickdown #448496
08/24/09 09:17 PM
08/24/09 09:17 PM
NJ
440challenger Offline OP
NJ
Just Got my Runner on the road and im trying to dial in the transmission. It will shift from 1st to 2nd at 2200-2300 rpm, then 3rd gear you really have to be cookin at over 3,000 rpm for it to got into 3rd gear. It also down shifts to soon in drive. Im running a new loakar kickdown cable. I didnt cut any off the cable and its adjusted for the most "slack " possible. There is no real slack in the cable but their is no tension so to speak either. I know on a GM the KD cable has slack until its almost wide open throttle.
I hope this can be an easy fix or atleast someone can point me in the right direction.
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448497
08/24/09 09:26 PM
08/24/09 09:26 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I adjust my kick down cable so when the throttle is wide open the kick down cable is pulled all the way "full on"
Then I test drive and begin adding slack until I like when the 1st to 2nd upshift occurs. The 2-3 upshift is usually OK at that point.
Re: 727 shifts late / lokar kickdown [Re: Lefty] #448498
08/24/09 09:31 PM
08/24/09 09:31 PM
Az
Crizila Offline
Crizila  Offline
Az
You are probably going to have to drill a new hole in the throttle pressure arm on the trans closer to the pivot shaft - around the same distance as the cable hook up on the carb.
Fastest 300
Re: 727 shifts late / lokar kickdown [Re: Lefty] #448499
08/24/09 09:31 PM
08/24/09 09:31 PM
NJ
NJ
So am i actually adjusting this setup the WRONG way? I need to take the slack out ? So when i go full throttle it adds slack?
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448500
08/24/09 09:34 PM
08/24/09 09:34 PM
Az
Crizila Offline
Crizila  Offline
Az
Sounds like you got the cable mounted wrong on the trans. As you open the throttle, the cable should be pulling the throttle shaft on the trans towards the rear of the trans.
Fastest 300
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448501
08/24/09 09:38 PM
08/24/09 09:38 PM
Lefty Offline
Lefty  Offline
No, as the throttle opens the kick down cable should be getting pulled "tighter" also...
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448502
08/24/09 09:42 PM
08/24/09 09:42 PM
scratchnfotraction Offline
lokar
when at wot you want it tight,pulling the throttle pressure valve lever all the way back..
drill a hole closr to the center shaft to correct ratio..result will vary
I have dozens of tpv lever from over the yrs,it is possable to find one thats clocked more than others on the tpv stem,this could help correct ratio also..the d hole is clocked diff and some arms are longer/shorter
this is the ? that the starts with when some one suggest the bouchillon kit over the lokar kit as being better...which it is
the bouchillon kit uses a late model set up and cable with the corret ratio throttle lever adaptor on the carb,its tuned for the mopar throttle pressure valve lever ratio on the tranz, so its much easier to fine tune the shift points
now the
Re: 727 shifts late / lokar kickdown [Re: Lefty] #448503
08/24/09 09:43 PM
08/24/09 09:43 PM
NJ
NJ
OK that is how i have it but I have NO adjustment left to give more slack in the cable and i didnt even cut any of the cable like the directiosn mentioned
Re: 727 shifts late / lokar kickdown [Re: scratchnfotraction] #448504
08/24/09 09:45 PM
08/24/09 09:45 PM
NJ
NJ
Ok so on the actual lever on the trans,drill a new hole about in the center you say?
Re: 727 shifts late / lokar kickdown [Re: Crizila] #448505
08/24/09 09:47 PM
08/24/09 09:47 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Re: 727 shifts late / lokar kickdown [Re: DAMOPARS] #448506
08/24/09 09:56 PM
08/24/09 09:56 PM
drill the hole next to the end one by a 1/8"...leave room for more holes if needed closer in to the d hole
may drill more than one to find the sweet spot if the drilled holes dont get you right..
let me know if you want a diff lever on the tranz,I can find one with the d-hole clock to give you more adjustment forward or back
I gots plenty,just need to see where yours is clocked at,and know which way to go with it
Re: 727 shifts late / lokar kickdown [Re: scratchnfotraction] #448507
08/24/09 10:04 PM
08/24/09 10:04 PM
NJ
NJ
Ok im going to tackle it tommrow. guess ill take the lever off to drill her out. Will let you know how i make out. Where about should it shift into 3rd under light throttle?
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448508
08/24/09 10:52 PM
08/24/09 10:52 PM
while you have it off,you can see how the D-hole is clocked
I hold it with the end a 6:00 and the D-hole at 12:00
make note of that,then if the holes dont provide enuff adjustment you can adjust it with another lever and then drill more holes if need be
thats the way i did it
Re: 727 shifts late / lokar kickdown [Re: 440challenger] #448509
08/25/09 04:46 PM
08/25/09 04:46 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Instead of randomly drilling holes, do it the right way.
Measure the total travel of the carburetor lever at the point the cable attaches, then run the transmission lever from full forward to full rearward and find the spot on the lever that matches the carb lever travel and drill the hole there.
You should also add a spring to pull the transmission lever forward.
Re: 727 shifts late / lokar kickdown [Re: John_Kunkel] #448510
08/25/09 04:57 PM
08/25/09 04:57 PM
Az
Crizila Offline
Crizila  Offline
Az
You said it much better than I did John.
Fastest 300
