Stock Rod Small blocks
#448480
08/24/09 09:10 PM
08/24/09 09:10 PM
Triple Threat
Renton Washington
Wondering who else is running stock rods in their motor still, how much power you're making and the number of passes you have on them. My 346 has propelled my 3500# Dart to 12.30@107.47. I've put roughly 400 passes on the rods and a number of street miles and foolish behavior. I shift the car at 5600 and go through the traps at 6000. Stock rods and bolts, cast piston, hyd. cam, etc etc , the limiter is set at 6200, so the motor isn't spun hard. How worried would you be? The engine currently has 256 passes on it since the last rering/bearing job, and all was well then, just curious if I'm on borrowed time or if I can still sleep well at night.
Re: Stock Rod Small blocks
[Re: emarine01]
#448485
08/24/09 09:38 PM
08/24/09 09:38 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I ran low 12s and lots and lots of street miles on my stock rod 340. It had a 6000shift point and I beat on it regularly(all the time i was 18 lol). Stock crank broke behind the last rod journal and it wasn't really fatal. It still ran, and still had oil pressure but it sounded like someone beating a frying pan with a hammer at idle, got quite under load. I put eagle rods and another crank in it and was back in action.
68 Barracuda Formula S 340
[Re: Bad340fish]
#448486
08/24/09 09:48 PM
08/24/09 09:48 PM
Posts: 1,481 Outside
thedriver
Outside
stock rods here, spin 'er to 6500 or so every time i take it out, over 15000 abusive miles on it, if it breaks, i get to build a bigger motor, so not too concerned.
1973 challenger Dana. 4 speed. Low deck.
[Re: thedriver]
#448488
08/24/09 09:59 PM
08/24/09 09:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a set of Viper rods in one of my 340's all balanced ... it ran about 2 seasons till a rod let go.... guess they didnt like 7500 rpm and that was with some fairly light pistons..... they all break, its just a matter of time and rpm
[Re: Lil Wedge]
#448489
08/24/09 10:01 PM
08/24/09 10:01 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
I have run a best of 11.24 @121 for been together for 8 years now hundreds of passes plus thousands of street miles 360 stock rods, stock crank, cast pistons, e-heads, '68 barracuda 3200# dyno at 421 at the rear wheels
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: Cudahlr]
#448490
08/24/09 10:25 PM
08/24/09 10:25 PM
Posts: 84 NC
Badfish67
NC
I'm running a stock crank and rods in my 360 and spraying 150 shot...tons of passes on it and its still holding up...coming through the traps at 6900 rpm's. This winter i'm going to forged H-beam rods and forged crank so I can spray a 250 shot.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Triple Threat]
#448491
08/24/09 10:26 PM
08/24/09 10:26 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
My AMC Spirit currently has a MP crate shortblock, ported Eddys, RPM Air Gap, 750 vac secondary, 3500 stall, low gearset 904, 3.89 gears, 325/50/15 BFG Drag Rads, 3100lb race wt. N/A has went 11.30 at 119 - 1.50 60', 6200 shifts,6100 trap rpm. On 100 shot went 10.51 at 126 - 1.42 60', 6200 shifts, 6450 trap rpm (window switch shuts NOS off at 6400). About 12K miles and 150 passes on motor. I try to keep rpms under 6500 on the stock rods. I'm considering a 3.50 gear and a 150 shot - should go through the traps at about 130 off the chip.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Thumperdart]
#448493
08/25/09 07:37 AM
08/25/09 07:37 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you're only turning it to 6K RPM, they'll last a looooong time, even with a fairly heavy piston, and at that, it'll probably be the bolts that fail, not the rod itself. what kills rods are the inertial forces from a heavy piston on the end of it suddenly changing direction. those forces increase IIRC by the square of the speed (say, 2000 to 4000 rpm is double the speed, but it'll be 4x the inertial forces). lighter pistons help, higher rod ratio helps due to lower piston accelerations for a given RPM.
