fixing a tapped hole..... #448321
08/24/09 07:28 PM
08/24/09 07:28 PM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
On a Holley. How would you go about repairing a hole in the main body on a Holley 850? I stripped one out that holds the fuel bowl on. I'm not sure what size they are, but can the main body even be repaired or is it junk?? I'd like to repair it so that I can sell it. I had to buy a brand new one in a pinch..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: fixing a tapped hole..... [Re: KatFysh] #448322
08/24/09 07:47 PM
08/24/09 07:47 PM
MNobody Offline
MNobody  Offline
If theres enough material there, helicoil it, if not fill the hole with JB weld maybe and re-drill and tap? Maybe plug the hole with the next size bigger bolt SAE or Metric, cut off the bolt flush, drill and tap to the next size smaller than the carb bolt, grind down the threaded end of the carb bolt and rethread it to the next smaaler size to fit the new thread in the main body.
Re: fixing a tapped hole..... [Re: MNobody] #448323
08/24/09 07:57 PM
08/24/09 07:57 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Previous suggestions sound good.
Another possibility, you might also be able to fit a "nut" on the inner-edge of the Main-Body near the exterior of the venturies. With a long enough bowl-screw, you could thread into it.
Maybe you could epoxy the nut in place, to make it semi-permanent.
Re: fixing a tapped hole..... [Re: D_C] #448324
08/24/09 08:29 PM
08/24/09 08:29 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
Summit racing... Holley Heli Coil Kit
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: fixing a tapped hole..... [Re: A70Runner] #448325
08/24/09 08:38 PM
08/24/09 08:38 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I had to heli coil mine because the threads pulled out. If you're gonna sell it that would be the way to go. Being pot metal, my heli coils eventually pulled out. So I got some brass set screws, drilled the hole and put the set screw in, then drilled and tapped the set screw for the bowl screw thread. Worked like a charm.
