Ebody console texture and TACH fabricated-Need imput??
#448073
08/24/09 01:47 PM
08/24/09 01:47 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
UPDATED/ PLEASE GO TO THE BOTTOM POST
Any ideas what to use??
I am completely changing my E body auto slapstick console to include a tac, which is now going to be fabricated into the console via some fiberglass and a metal frame. After the lighweight filler is applied and I sand it for paint, I need to achieve the stock texture or alter the stock texture.
anybody discovered anything. I may have to change the texture of the whole thing to match.
Re: Achieving E body stock console texture????
[Re: cataclysm80]
#448076
08/24/09 03:57 PM
08/24/09 03:57 PM
RUMBLON
Cambridge Idaho
It's not so much a texture as a grain pattern. It's not really something you can spray on.
It's very very tedious, but I saw someone cut the pattern into a very small section of repaired console.
For a bigger area, you might try using something to make a mold of the original texture that you can press onto the still wet surface of your fabricated part.
Tav
Maybe I will just spray over it and make another texture.
[Re: RUMBLON]
#448077
08/24/09 04:12 PM
08/24/09 04:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Dave you might want to pick up a can of Rustoleums spray on bed liner, in a red/white spray can at AutoZone, about $4,....tough as nails, if you spray it with some distance, has a nice texture, just knock it down with sandpaper later, to slightly flatten the surface like whats on a stock E body console, or E body interior grain, then coat it with SEM's Landau Black to restore color....I just fabricated a radio delete plate, and happened apon the stuff experimenting with textured finishes,
Mike
[Re: DAYCLONA]
#448078
08/24/09 06:04 PM
08/24/09 06:04 PM
RUMBLON
Cambridge Idaho
Mike, thanks a ton, I will look for the stuff.
thanks again
I spent the day doing/ making this
Mike
[Re: RUMBLON]
#448082
08/25/09 12:21 PM
08/25/09 12:21 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike is this the stuff????
yes
