Ebody console texture and TACH fabricated-Need imput?? #448073
08/24/09 01:47 PM
08/24/09 01:47 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
UPDATED/ PLEASE GO TO THE BOTTOM POST
Any ideas what to use??
I am completely changing my E body auto slapstick console to include a tac, which is now going to be fabricated into the console via some fiberglass and a metal frame. After the lighweight filler is applied and I sand it for paint, I need to achieve the stock texture or alter the stock texture.
anybody discovered anything. I may have to change the texture of the whole thing to match.
Re: Achieving E body stock console texture???? [Re: RUMBLON] #448074
08/24/09 02:39 PM
08/24/09 02:39 PM
cataclysm80 Offline
cataclysm80  Offline
It's not so much a texture as a grain pattern. It's not really something you can spray on.
It's very very tedious, but I saw someone cut the pattern into a very small section of repaired console.
For a bigger area, you might try using something to make a mold of the original texture that you can press onto the still wet surface of your fabricated part.
Tav
Re: Achieving E body stock console texture???? [Re: cataclysm80] #448075
08/24/09 03:57 PM
08/24/09 03:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can use your console to make a "grain pattern die". Go to this link;
http://www.hamtramck-historical.com/1969-Dodge-TSB-Index.shtml
& read TSB No.D69-23-16 (it is in chapter 23 & is 13 pages long)
It is about vinyl top repair, but the process is related.
Re: Achieving E body stock console texture???? [Re: cataclysm80] #448076
08/24/09 03:57 PM
08/24/09 03:57 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Tav
Maybe I will just spray over it and make another texture.
Re: Achieving E body stock console texture???? [Re: RUMBLON] #448077
08/24/09 04:12 PM
08/24/09 04:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dave you might want to pick up a can of Rustoleums spray on bed liner, in a red/white spray can at AutoZone, about $4,....tough as nails, if you spray it with some distance, has a nice texture, just knock it down with sandpaper later, to slightly flatten the surface like whats on a stock E body console, or E body interior grain, then coat it with SEM's Landau Black to restore color....I just fabricated a radio delete plate, and happened apon the stuff experimenting with textured finishes,
Mike
Re: Achieving E body stock console texture???? [Re: DAYCLONA] #448078
08/24/09 06:04 PM
08/24/09 06:04 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Mike, thanks a ton, I will look for the stuff.
thanks again
I spent the day doing/ making this
Mike
Re: Achieving E body stock console texture???? [Re: RUMBLON] #448079
08/24/09 06:06 PM
08/24/09 06:06 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Mike is this the stuff????
Re: Need imput-E body console texture! TACH fab!!!!!! [Re: RUMBLON] #448080
08/25/09 11:53 AM
08/25/09 11:53 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I know its a not the general section, but I need some imput on this and the texture, ect.
I am curious if you guys like this or not, what ya think????
please check it out. I know the question answer crowd has a lot of do it your self types on here.
linky https://board.moparts.org/ubbthreads/show...c=1#Post5439595
Re: Need imput-E body console texture! TACH fab!!!!!! [Re: RUMBLON] #448081
08/25/09 11:55 AM
08/25/09 11:55 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
near finished
Re: Achieving E body stock console texture???? [Re: RUMBLON] #448082
08/25/09 12:21 PM
08/25/09 12:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
yes
