Re: Anybody sell neutral safety switch 68-70 Bbody 4speed?
[Re: Blakcharger440]
#448064
08/24/09 02:45 PM
08/24/09 02:45 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Starting in 70 there was a switch on the pedal that required you to push the clutch to start the car.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Jim_Lusk]
#448067
08/24/09 07:42 PM
08/24/09 07:42 PM
Posts: 643 southern conn
1969gtx
southern conn
In 1970 a clutch s/w was on all b/e body thay are available from berwers prformance thay have a thread in trans for sale
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: MO_PA]
#448069
08/24/09 09:41 PM
08/24/09 09:41 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
What about 68 cars without the dash reverse light???
Nope, started in 1970.
[Re: 68CoronetRT]
#448070
08/25/09 04:59 PM
08/25/09 04:59 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The dash Reverse warning lamp was available in '69, came with the Track-Pak and Super Track-Pak.
[Re: BRawls]
#448072
08/26/09 02:01 PM
08/26/09 02:01 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
John -
I had two '68 Road Runners that both had "reverse" lights on the dash. I thought there was a trans switch just worked the tail reverse lights?
It's simple wiring to get the switch to control three lights instead of only two.......
