Anybody sell neutral safety switch 68-70 Bbody 4speed? #448063
08/24/09 01:37 PM
08/24/09 01:37 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Does anybody sell a neutral safety switch for a 68-70 B-body 4speed Mopar? I dont know if this switch was used on other cars or not.
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: Blakcharger440] #448064
08/24/09 02:45 PM
08/24/09 02:45 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Starting in 70 there was a switch on the pedal that required you to push the clutch to start the car.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: Blakcharger440] #448065
08/24/09 03:20 PM
08/24/09 03:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My 68 plymouth never had one just a light to let you know you were in reverse. A limiting switch under the clutch peddle would work. all a neutral safety switch does is allow the ground on the G terminal of the starter relay to ground if it is grouned go, no ground no go. my original Relay had no ground terminal
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: Blakcharger440] #448066
08/24/09 05:07 PM
08/24/09 05:07 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
No such part on a 68 or 69.
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: Jim_Lusk] #448067
08/24/09 07:42 PM
08/24/09 07:42 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
In 1970 a clutch s/w was on all b/e body thay are available from berwers prformance thay have a thread in trans for sale
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: Dodgem] #448068
08/24/09 08:25 PM
08/24/09 08:25 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
What about 68 cars without the dash reverse light???
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: MO_PA] #448069
08/24/09 09:41 PM
08/24/09 09:41 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Nope, started in 1970.
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: 68CoronetRT] #448070
08/25/09 04:59 PM
08/25/09 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The dash Reverse warning lamp was available in '69, came with the Track-Pak and Super Track-Pak.
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: John_Kunkel] #448071
08/25/09 07:14 PM
08/25/09 07:14 PM
BRawls Offline
super gas
BRawls  Offline
super gas
John -
I had two '68 Road Runners that both had "reverse" lights on the dash. I thought there was a trans switch just worked the tail reverse lights?
Re: Anybody sell neutral safety switch 68-70 Bbody 4speed? [Re: BRawls] #448072
08/26/09 02:01 PM
08/26/09 02:01 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
John -
It's simple wiring to get the switch to control three lights instead of only two.......
