Re: valve lash
[Re: maxie]
#447991
08/24/09 10:57 AM
08/24/09 10:57 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Aluminum or iron heads?They get set different.My Comp I set at about .004 tighter than spec on my aluminum heads.Cold I set them at about the cam spec.That way they are just a bit tighter and its been like that for 5 years with no problems.Rocky
Chrysler Firepower
Re: valve lash
[Re: Cab_Burge]
#447994
08/24/09 12:30 PM
08/24/09 12:30 PM
therocks
Niles , Ohio
Just remember that a little tight gives you a bit more lift and if solids a little less noise.Loose less lift and a little more noise.I check mine like twice a year.Usually they are dead on.Rocky
Chrysler Firepower
Re: valve lash
[Re: Mr.Yuck]
#447998
08/24/09 01:18 PM
08/24/09 01:18 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
On iron heads I used to set intake .002 loose and exhaust .004 loose (never went .028/.032 on anything .022/.024 is lots hot even on them old tech cams). On my Indy heads (taller than eddies and grow more) I go .010 tight intake and .008 tight exhaust seem to be right hot?? on eddies I go .006 and .004 tight cold!! a few thou one way or another does little as ling as there is .012 or more play hot!!
Re: valve lash
[Re: maxie]
#448001
08/25/09 02:00 AM
08/25/09 02:00 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
I dont think it makes a difference and I understand the aluminum shrinking and expanding with heat and the larger the head the more material to contract and expand, that being said this is a hemi so does the .014 on a cold head still sound right?
Absolutely I have had several aluminum headed cast iron blocks hemi on the engine dyno, .014 should be real close to perfect unless you have aluminum roller rockers and then it may need less lash when cold Don't forget that no two motors are exactly alike on any of the parts, you should start with .006 to .008 less lash cold and then warm rhe motor up like you normally drive it and then recheck the lash when hot and vereify what it actually changes and adjust from there. I know, them dang Hemoroids are a real pain to get the plugs, out, remove the valve covers and so on It is a lot easier on the dyno than in the car, especially the drivers side
Re: valve lash
[Re: Dodgem]
#448007
08/25/09 12:39 PM
08/25/09 12:39 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
humm maybe I'll snug mine down some then
