727 clutch pack problem? #447646
08/23/09 11:09 PM
08/23/09 11:09 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
hi
ihave a 727 in my 65 coronet that has a rear clutch pack seized together.Has anyone ever torn one apart and fixed the problem thierselves. THe car wants to go forward no matter where the gear selector is located. any imfo appreiciated
thanks gene
Re: 727 clutch pack problem? [Re: 3wracing] #447647
08/24/09 07:40 AM
08/24/09 07:40 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's prbably a broken return spring. Pull the trans apart and pull the foward cluth apart and repair it. Or replace it, depending.
Re: 727 clutch pack problem? [Re: moper] #447648
08/24/09 09:23 AM
08/24/09 09:23 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Drives forward in reveres too??
Re: 727 clutch pack problem? [Re: Dodgem] #447649
08/24/09 08:47 PM
08/24/09 08:47 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
which way do the clutches come out? are they behind the pump or do i goin from the other end any help appreciated
thanks gene
Re: 727 clutch pack problem? [Re: 3wracing] #447650
08/24/09 08:54 PM
08/24/09 08:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
everything comes out the front save for the valve body and output shaft. build a rig like this
Re: 727 clutch pack problem? [Re: Dodgem] #447651
08/24/09 08:55 PM
08/24/09 08:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
and
Re: 727 clutch pack problem? [Re: Dodgem] #447652
08/24/09 08:57 PM
08/24/09 08:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
first
Re: 727 clutch pack problem? [Re: Dodgem] #447653
08/24/09 08:58 PM
08/24/09 08:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 727 clutch pack problem? [Re: Dodgem] #447654
08/24/09 08:59 PM
08/24/09 08:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 727 clutch pack problem? [Re: Dodgem] #447655
08/25/09 05:26 PM
08/25/09 05:26 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
thankyou very much for the imfo
gene
