B Body exhaust systems #447258
08/23/09 04:50 PM
08/23/09 04:50 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
I need an exhaust system for my 67 Hemi Charger and was considering using Dons Custom exhaust from Ohio. Has anyone had any experience with his products and service? IF so, How is the fit and quality of his products? Looking for a cheaper alternative than Accurate LTD in Oregon. Shipping alone from Oregon to Florida is 180.00.
Santo
Re: B Body exhaust systems [Re: hemi67] #447259
08/23/09 05:18 PM
08/23/09 05:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A friend of mine just purchased an H-pipe and tail pipes from Dons . for a 67 Coronet R/T 440 car.
I will not know for about 3 weeks(or more)at the best in regards to fit.
But based on a very high recomendation from Jim Drain was all we needed
Re: B Body exhaust systems [Re: hemi67] #447260
08/24/09 02:10 PM
08/24/09 02:10 PM
St. Louis
I
Imrare Offline
Imrare  Offline
I
St. Louis
I purchased a complete exhaust system for my 1969 Roadrunner from Don's and I am extremely satisfied. It fit like it should with very little "tweaking" and it is factory correct.
Re: B Body exhaust systems [Re: Imrare] #447261
08/24/09 03:06 PM
08/24/09 03:06 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Does anyone know how to contact Don's? Thanks Ronnie
Re: B Body exhaust systems [Re: okie] #447262
08/24/09 04:25 PM
08/24/09 04:25 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Accurate is just a little over an hour from me.. I used there entire system on my 67 coronet with a 440 and there "hiflow" hemi mufflers.. fit like a glove and sounds great.. I would highly reccomend them, but I do understand the shipping costs.. If dons is anything close you will be very happy....
Re: B Body exhaust systems [Re: okie] #447263
08/24/09 04:55 PM
08/24/09 04:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Don's Custom Exhaust
2170 Parks Ave, S. E.
Paris, Ohio 44669
1-330-862-2096
Re: B Body exhaust systems [Re: gtx6970] #447264
08/24/09 06:01 PM
08/24/09 06:01 PM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
I bought my head pipes from Don's at Carlisle and they were perfect. Highly recommended.
Re: B Body exhaust systems [Re: T2R9] #447265
08/24/09 07:21 PM
08/24/09 07:21 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks to all who responded . You were very helpful. Dons it will be.
Santo
Re: B Body exhaust systems [Re: hemi67] #447266
08/28/09 11:34 PM
08/28/09 11:34 PM
o'fallon, MO
Brian_E Offline
Brian_E  Offline
o'fallon, MO
gardner exhaust is excellent, just bought a concourse grade charger exhaust from them. a+
Re: B Body exhaust systems [Re: Brian_E] #447267
08/29/09 07:01 AM
08/29/09 07:01 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Has anyone purchased an exhaust from DALES CUDA SHOP? If so, your opinion?
Re: B Body exhaust systems [Re: rayztoy] #447268
08/29/09 08:19 AM
08/29/09 08:19 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You should do better price wise with someone that makes/markets their own over someone that sells someone elses product.As far as Don's is concerned,you won't find anything that fits any better.20yrs ago I was selling him OEM pipes to use as patterns.
Re: B Body exhaust systems [Re: 62maxwgn] #447269
08/29/09 11:37 AM
08/29/09 11:37 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I got an H-pipe for my 70 Hemi Charger from Don's. I was happy that it looked correct, but when I went to fit it the pipes were way off at the tail and would have rubbed the driveshaft. Since both R & L were to the same side I was left with no choice but to saw off a 3/16s at the manifold flange, reflange it again and HOPE I guessed right. You don't have much room for error on this. Luckily it fit after the first try. I had to do this same procedure 20 years ago with an H-pipe on a Hemi Cuda. If I had to do it all again I would tell them to NOT weld in the crossover pipe and ship it loose. Once that crossover is welded in place your ability to tweak ANYTHING is LIMITED.
Re: B Body exhaust systems [Re: rayztoy] #447270
08/30/09 02:59 PM
08/30/09 02:59 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Anyone?
Re: B Body exhaust systems [Re: rayztoy] #447271
08/30/09 06:24 PM
08/30/09 06:24 PM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
I purchased a set of hemi mufflers and hangers from them last week. I was very impressed with the way I was treated. Quick and curteous service!
Re: B Body exhaust systems [Re: sch1966] #447272
08/31/09 05:53 PM
08/31/09 05:53 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Thanks for the reply!
