Torque converter bolts coming loose!!! HELP!! #447054
08/23/09 01:04 PM
08/23/09 01:04 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Well it was the first real outing for the 636 engine and on its first pull it ran great no problems but then we heard a wierd noise. We couldn't figure it out right away but when we were gonna make our second pull we found out a converter bolt was working its way out. Got it home and all four were loose!
We Doubled checked each one when tightening each bolt and had red locktight on them as well.
What can cause this and what is the solution???
This is a new trans and Convertor.
We ran the old trans and convertor with this 636ci engine once as a test run and nothing was wrong with the bolts on the old convertor.
Doug
Re: Torque converter bolts coming loose!!! HELP!! [Re: Diablo] #447055
08/23/09 01:15 PM
08/23/09 01:15 PM
PA
moparacer Offline
moparacer  Offline
PA
Well I will tell you my converter bolt story but you wont like to hear it.
A few years back mine kept coming loose and after a couple flexplates and aggravation the crank ended up breaking.
I think the crank being cracked was loosening the bolts...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Torque converter bolts coming loose!!! HELP!! [Re: Diablo] #447056
08/23/09 01:17 PM
08/23/09 01:17 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
There could be an imbalance in the converter and/or flex-plate.
Re: Torque converter bolts coming loose!!! HELP!! [Re: dOoC] #447057
08/23/09 01:33 PM
08/23/09 01:33 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Sounds like a vibration issue.
Re: Torque converter bolts coming loose!!! HELP!! [Re: Diablo] #447058
08/23/09 04:13 PM
08/23/09 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There have been numerous previous threads about converter bolts working loose and I don't think there was ever a common consensus as to why some do and most don't.
My suggestion for problematic bolts has always been to drill the bolts for safety wire.
Re: Torque converter bolts coming loose!!! HELP!! [Re: John_Kunkel] #447059
08/23/09 04:18 PM
08/23/09 04:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I use red loctite
Re: Torque converter bolts coming loose!!! HELP!! [Re: Dodgem] #447060
08/23/09 04:33 PM
08/23/09 04:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use red locktite and I use a impact to tighten them,
on a small block I can get to them in the starter
area... I give them a couple of hits with the gun...
dont go crazy
Re: Torque converter bolts coming loose!!! HELP!! [Re: MR_P_BODY] #447061
08/23/09 04:37 PM
08/23/09 04:37 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
dont go crazy
P-guy ... you are going to drive the "PRECISE TORQUE guys" cRaZy saying stuff like that.
.....a couple of hits with-da'-gun ...
Re: Torque converter bolts coming loose!!! HELP!! [Re: dOoC] #447062
08/23/09 04:47 PM
08/23/09 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
dont go crazy
LOL... I figured so.... there are only a few things
I really torque on a engine and the verter bolts
arent one of them
Re: Torque converter bolts coming loose!!! HELP!! [Re: BergmanAutoCraft] #447063
08/23/09 05:11 PM
08/23/09 05:11 PM
It won't fix itself, it will breaak stuff if you don't fix it now before it does break valuable parts. Harmonics and vibrations can loosen a lot of things held together with bolts and nuts, figuring out which one it(harmonics or vibrations) is, is the hard part Let us know what you find and do please, it may help someoone else on here down the road. What stroke and bore is this motor? What was the bore and stroke on the smaller one?
Re: Torque converter bolts coming loose!!! HELP!! [Re: Cab_Burge] #447064
08/23/09 05:39 PM
08/23/09 05:39 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
New trans could be off,Check alignment.Between crank and trans
Ain't nuthin like a HEMI !
Re: Torque converter bolts coming loose!!! HELP!! [Re: Mulehead] #447065
08/23/09 06:16 PM
08/23/09 06:16 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
The torque will be coming out early this week. I need this problem fixed by next weekend. Take the torque back to the builder to make sure its balanced. Or maybe put the old torque back in and see if they don't back up with that one. Like i mentioned using this engine (636ci) and the old trans and converter we made two passes and everything was fine. One pass with the new trans and converter and all 4 bolts came loose with red lock tight.
Bore is 4.500
Stroke is 5 inch.
Engine has a solid elephant ears, solid mid plate and rubber on the the rear of trans.
Re: Torque converter bolts coming loose!!! HELP!! [Re: Diablo] #447066
08/23/09 08:25 PM
08/23/09 08:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Were the threads clean& dry??No oil of ANY kind??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Torque converter bolts coming loose!!! HELP!! [Re: Diablo] #447067
08/23/09 08:38 PM
08/23/09 08:38 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I had them back out with locktite before. I started using RTV silicon on them and haven't had one come loose since. That was over 20 years ago.
Re: Torque converter bolts coming loose!!! HELP!! [Re: hemi-itis] #447068
08/23/09 08:40 PM
08/23/09 08:40 PM
Hemitis, does this look familiar.
Re: Torque converter bolts coming loose!!! HELP!! #447069
08/23/09 08:50 PM
08/23/09 08:50 PM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
You might check your driveshaft. I kept bending mine about .03 -.05 and made an awful vibration and convertor bolts kept coming loose. I went to a 4" aluminum driveshaft and the vibration stopped and convertor bolts have been tight all year.
Jack
Re: Torque converter bolts coming loose!!! HELP!! #447070
08/23/09 08:50 PM
08/23/09 08:50 PM
start with new converter bolts, spray brakekleen in converter holes, red loctite and after you get bolts tight, hit vthe wrench with a hammer for extra torque, you probably didnt go tight enough.
pictures care of the HEMITIS archives
Re: Torque converter bolts coming loose!!! HELP!! #447071
08/23/09 10:21 PM
08/23/09 10:21 PM
hemi-itis Offline
hemi-itis  Offline
YES SSR,Those are the new converter bolts we put in your hemi car at PINKS ALL OUT at Englishtown.They didn't come loose after that.
