Page 1 of 4 1 2 3 4
can someone school me on setting pinion angle?? #446838
08/23/09 10:12 AM
08/23/09 10:12 AM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I need to know what the easist way to set a pinion angle with a 4 link system. I have been told to put a angel finder on the crank pulley and get the angle is that right?
www.sikosracing.net Heads up Drag racing
Re: can someone school me on setting pinion angle?? [Re: moparmattkos] #446839
08/23/09 10:23 AM
08/23/09 10:23 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Here's an online course.
"PINION ANGLE"
Re: can someone school me on setting pinion angle?? [Re: S/ST 3040] #446840
08/23/09 10:51 AM
08/23/09 10:51 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Just PM Quktree or sixpackgut
Mopar Performance
Re: can someone school me on setting pinion angle?? [Re: S/ST 3040] #446841
08/23/09 11:02 AM
08/23/09 11:02 AM
, PA
sleepyhead416 Offline
, PA
Check out MOPARTS TECH archives. If its not there it should be seems like a weekly ? Or try search
Re: can someone school me on setting pinion angle?? [Re: moparniac] #446842
08/23/09 11:08 AM
08/23/09 11:08 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yeah there is tech video on the here somewhere, very informative
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: can someone school me on setting pinion angle?? [Re: DemonDust] #446843
08/23/09 12:48 PM
08/23/09 12:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you still have my #
Re: can someone school me on setting pinion angle?? [Re: moparmattkos] #446844
08/23/09 01:38 PM
08/23/09 01:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Now where's that video Dram made?
Re: can someone school me on setting pinion angle?? [Re: moparmattkos] #446845
08/23/09 01:43 PM
08/23/09 01:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You are correct. Pinion angle is the relationship between the pinion centerline and the crank/transmission centerline.
Make the pinion parallel to the transmission as a base-line, then pivot the pinion downward 2-3 degrees. In other words, the resulting pinion angle will be 2-3 degrees under parallel (nose down) to the transmission centerline when the car is at rest.
BTW, there are some jokers around here who say I'm telling you to index the transmission angle relative to the pinion instead of the other way around.
Re: can someone school me on setting pinion angle?? [Re: DoctorDiff] #446846
08/23/09 01:53 PM
08/23/09 01:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I see a movie being made now of drdiff by the haters
Re: can someone school me on setting pinion angle?? [Re: Quicktree] #446847
08/23/09 02:27 PM
08/23/09 02:27 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
No DR Diff hater here. I just wish he lived closer than BuzzardBreath Wyoming. I'd have a dana in my minivan !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: can someone school me on setting pinion angle?? [Re: sunroofgtx] #446848
08/23/09 05:05 PM
08/23/09 05:05 PM
Bad excuse, UPS, Fed Ex abd others deliver get one now before Quicktree breaks all of them even Quicktree can't break a Dana 60
Re: can someone school me on setting pinion angle?? [Re: Cab_Burge] #446849
08/23/09 05:25 PM
08/23/09 05:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I am going to try like hell
Re: can someone school me on setting pinion angle?? [Re: Quicktree] #446850
08/23/09 05:28 PM
08/23/09 05:28 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
just wait for Ray to get back from his boon doggle with you know who and have him set it up.
Re: can someone school me on setting pinion angle?? [Re: TS3303] #446851
08/23/09 06:05 PM
08/23/09 06:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea but no thanks
Re: can someone school me on setting pinion angle?? [Re: DoctorDiff] #446852
08/23/09 09:28 PM
08/23/09 09:28 PM
Make the pinion parallel to the transmission as a base-line, then pivot the pinion downward 2-3 degrees. In other words, the resulting pinion angle will be 2-3 degrees under parallel (nose down) to the transmission centerline when the car is at rest.............
I gotta say that I respectfully disagree with doing it that way........at least with a leaf spring car anyway.........
On my cars, and anything with decent power, especially with a stick, I'd always set the pinion down 7* with relationship to the driveshaft and it's ALWAYS worked great.......but, after reading here on Moparts how I need to set it to the crank centerline by Tony (Quicktree) so many times, I decided to do it that way on my just finished 68 GTS...........but first I've got to warn you that I did put 1" spacers between the K-frame and the body to lower the engine in the car which points the tail housing up a few degrees............
I set the pinion angle 7* down from the crankshaft center line and the car was fine until I let off the gas and it howled SO BAD I thought the rearend was was going to come apart.......... so, thanks to all the pinion angle threads on Moparts, I had to pull the rearend back out, cut the perches off, and reweld them back on.........this time with the angle 7* down from the driveshaft and it works GREAT now.........
So, I will NEVER set pinion angle that way again.........that's my on this.........
Re: can someone school me on setting pinion angle?? #446853
08/23/09 09:38 PM
08/23/09 09:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ever think 7 maybe to much and I didn't invent the method. it is taught by people who run a lot faster than you or I will ever run. think about the purpose of setting pinion angle. setting it off of the drive shaft ignores the front ujoint totally. ever think the springs maybe wearing out letting the pinon go more than the desired amount? remember the guess of 7* down or what ever is just a guess. no way to figure out the perfect amount except trail and error or maybe some kind of video.
Re: can someone school me on setting pinion angle?? [Re: Quicktree] #446854
08/23/09 09:43 PM
08/23/09 09:43 PM
Like I'd mentioned.......that was with a leaf spring car, and it does have slicks, and it does make close to 600HP, and I does launch like I stole it......and I doesn't want the driveshaft to smack the floor pan when I do........been there, done that.....
The thing you're forgetting is that a LOT of places recommend 6 to 7* pinion angle with a leaf spring car that's making some poop, and my car would not work doing it that way.............that's all I'm saying........
Re: can someone school me on setting pinion angle?? #446855
08/23/09 09:47 PM
08/23/09 09:47 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
NEVER had a 4 link ... but 7 degrees ?
On a suspension that should have ZERO change of pinion angle through the up and down movement.
That type of an angle is costing power.
Re: can someone school me on setting pinion angle?? #446856
08/23/09 09:50 PM
08/23/09 09:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
another thing, not many if any leaf cars have a motor/tranny centerline angle going up.. just something to think about before you condem the method.
Re: can someone school me on setting pinion angle?? [Re: dOrk !] #446857
08/23/09 09:51 PM
08/23/09 09:51 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
What about leafspring caltracs
Mopar Performance
Page 1 of 4 1 2 3 4
