Re: Distributer modifying
[Re: RapidRobert]
#446712
08/23/09 09:11 AM
08/23/09 09:11 AM
Posts: 531 Virginia
JimG
Virginia
Rapid Robert and others: Slightly OT, but this chart has been floating around Moparts for some time: dist. degrees X 2 + initial= total dist. degrees / slot size 6.............. .340 7............... .355 8............... .375 9............... .390 10.............. .405 11.5 ........... .420 12.............. .435 13.............. .445 14.............. .460 15.............. .475 16.............. .490 17.............. .505 18.............. .520 Last week I used the chart for the first time (in the past, I just used the trial-and-error method - kept filing until I had the slot length correct). I needed 8.5 distributor degrees, and ended up needing a slot that was around .410" to get it. I checked it with 2 different timing lights (a dialback Snap-On and a non-adjustable Craftsman with a timing tape). I've recently read about timing lights being inaccurate at high RPM, but both timing lights agreed w/each other, FWIW. My question: has anyone confirmed the accuracy of the chart? And if the chart is accurate, what am I missing? This certainly seems simple enough... Thanks, Jim
[Re: 62maxwgn]
#446715
08/23/09 09:51 AM
08/23/09 09:51 AM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
Only if you don't run it on the street!
Absolutely correct, this modification is for street use only...And strip.
[Re: JimG]
#446716
08/23/09 10:10 AM
08/23/09 10:10 AM
RapidRobert
JimG thanks for the heads up as I'm going to be using the chart for the first time here real soon.
[Re: Bill MeLater]
#446717
08/23/09 10:19 AM
08/23/09 10:19 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
While you're at it, do yourself a favor and very carefully remove the vacuum canister, smash it flat with a hammer, throw it in the garbage and weld these two plates together. Your motor will thank you for it..
This method locks the timing advance currect? How many areas does it needed to be welded at? do you have to set anything else or just take the advance off and springs off and weld the plates?
[Re: RapidRobert]
#446718
08/23/09 10:22 AM
08/23/09 10:22 AM
Posts: 531 Virginia
JimG
Virginia
Robert:
Shout back with your results.
Thanks,
[Re: moparmattkos]
#446719
08/23/09 10:25 AM
08/23/09 10:25 AM
As much as it pains me to bring this up--because I think the problem is vastly overblown-- when/if you weld an advance plate, CHECK the rotor phasing, and make sure with a reluctor that where you end up with the plate that you have enough range to properly adjust the reluctor gap.
IF you look the plate over, you'll find that the two "sit" parallel on two little shoes. You need to make sure this is OK before you tack it together. Doesn't take much to hold it but it DOES need to be correct.
Just me, but if I was going to all this work in this day 'n age, I'd go aftermarket.
#446721
08/23/09 10:33 AM
08/23/09 10:33 AM
Bill MeLater
Wisconsin USA
[Re: JimG]
#446723
08/23/09 12:58 PM
08/23/09 12:58 PM
Posts: 3,895 Oregon
hooziewhatsit
I welded up the thingy in my 318 distributor, and observed results like the chart says. In fact, originally, the stock heavy spring was heavy enough, it was acting as an advance limiter (I never go over 3k; work truck). If you take out the vac advance and weld that plate in place, you'll lose any advance from the vacuum. You'll still have mechanical advance. The only benefit to doing this would be to keep the plate from jittering around and bouncing the timing. Or, if it's solely a race engine. For the street, I'd tune it so it works
