Distributer modifying #446709
08/23/09 02:50 AM
08/23/09 02:50 AM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Which slots get welded when recurving a dist.for a BB? Any pics?
Re: Distributer modifying [Re: Rosco] #446710
08/23/09 03:02 AM
08/23/09 03:02 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Here's a How-To from Kribel & Kribel:
How To
Below are pictures of the advance slots:
Re: Distributer modifying [Re: Rosco] #446711
08/23/09 08:48 AM
08/23/09 08:48 AM
these
Re: Distributer modifying [Re: RapidRobert] #446712
08/23/09 09:11 AM
08/23/09 09:11 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Rapid Robert and others:
Slightly OT, but this chart has been floating around Moparts for some time:
dist. degrees X 2 + initial= total
dist. degrees / slot size
6.............. .340
7............... .355
8............... .375
9............... .390
10.............. .405
11.5 ........... .420
12.............. .435
13.............. .445
14.............. .460
15.............. .475
16.............. .490
17.............. .505
18.............. .520
Last week I used the chart for the first time (in the past, I just used the trial-and-error method - kept filing until I had the slot length correct).
I needed 8.5 distributor degrees, and ended up needing a slot that was around .410" to get it.
I checked it with 2 different timing lights (a dialback Snap-On and a non-adjustable Craftsman with a timing tape). I've recently read about timing lights being inaccurate at high RPM, but both timing lights agreed w/each other, FWIW.
My question: has anyone confirmed the accuracy of the chart? And if the chart is accurate, what am I missing? This certainly seems simple enough...
Thanks,
Re: Distributer modifying [Re: JimG] #446713
08/23/09 09:41 AM
08/23/09 09:41 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
While you're at it, do yourself a favor and very carefully remove the vacuum canister, smash it flat with a hammer, throw it in the garbage and weld these two plates together. Your motor will thank you for it..
Re: Distributer modifying [Re: Bill MeLater] #446714
08/23/09 09:45 AM
08/23/09 09:45 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Only if you don't run it on the street!
Re: Distributer modifying [Re: 62maxwgn] #446715
08/23/09 09:51 AM
08/23/09 09:51 AM
Wisconsin USA
Wisconsin USA
Absolutely correct, this modification is for street use only...And strip.
Re: Distributer modifying [Re: JimG] #446716
08/23/09 10:10 AM
08/23/09 10:10 AM
JimG thanks for the heads up as I'm going to be using the chart for the first time here real soon.
Re: Distributer modifying [Re: Bill MeLater] #446717
08/23/09 10:19 AM
08/23/09 10:19 AM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
This method locks the timing advance currect? How many areas does it needed to be welded at? do you have to set anything else or just take the advance off and springs off and weld the plates?
www.sikosracing.net Heads up Drag racing
Re: Distributer modifying [Re: RapidRobert] #446718
08/23/09 10:22 AM
08/23/09 10:22 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Robert:
Shout back with your results.
Thanks,
Re: Distributer modifying [Re: moparmattkos] #446719
08/23/09 10:25 AM
08/23/09 10:25 AM
As much as it pains me to bring this up--because I think the problem is vastly overblown-- when/if you weld an advance plate, CHECK the rotor phasing, and make sure with a reluctor that where you end up with the plate that you have enough range to properly adjust the reluctor gap.
IF you look the plate over, you'll find that the two "sit" parallel on two little shoes. You need to make sure this is OK before you tack it together. Doesn't take much to hold it but it DOES need to be correct.
Just me, but if I was going to all this work in this day 'n age, I'd go aftermarket.
Re: Distributer modifying [Re: JimG] #446720
08/23/09 10:33 AM
08/23/09 10:33 AM
I will do and I am trying to drill the ends of the slots & add set screws so I can adj it externally but I'm having a hard time finding a #43 drill bit hard enough. Any suggestions
Re: Distributer modifying #446721
08/23/09 10:33 AM
08/23/09 10:33 AM
Wisconsin USA
Wisconsin USA
Re: Distributer modifying [Re: RapidRobert] #446722
08/23/09 11:38 AM
08/23/09 11:38 AM
Virginia
JimG Offline
JimG  Offline
Virginia
No specific experience, but here's a thought. McMaster-Carr has a wide variety of bits. Perhaps Cobalt Steel or Powdered Metal Steel would survive. I see they have both in #43.
Oops, forgot the link...http://www.mcmaster.com/#drill-rods/=3bfmng
Re: Distributer modifying [Re: JimG] #446723
08/23/09 12:58 PM
08/23/09 12:58 PM
hooziewhatsit Offline
I welded up the thingy in my 318 distributor, and observed results like the chart says.
In fact, originally, the stock heavy spring was heavy enough, it was acting as an advance limiter (I never go over 3k; work truck).
If you take out the vac advance and weld that plate in place, you'll lose any advance from the vacuum. You'll still have mechanical advance.
The only benefit to doing this would be to keep the plate from jittering around and bouncing the timing. Or, if it's solely a race engine. For the street, I'd tune it so it works
