Indy 440-25 cross ram #446121
08/22/09 02:58 PM
08/22/09 02:58 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Well I guess I am going to order one monday any thing I need to know to make it work and does anyone have a used one to sell anyone seen a better price then $995??
Re: Indy 440-25 cross ram [Re: biff426] #446122
08/23/09 09:16 AM
08/23/09 09:16 AM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
Like this one blow off's or what BGR calles sneezer valves are a must imo.
Re: Indy 440-25 cross ram [Re: max_maniac] #446123
08/23/09 09:20 AM
08/23/09 09:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The price has come down. I bought one of the 1st pieces when they came out,$1400. I don't use the blow off valves. I start the engine with the throttle open in case of back fire. That way the pressure escapes past the throttle blades.
Doug
Re: Indy 440-25 cross ram [Re: max_maniac] #446124
08/23/09 09:25 AM
08/23/09 09:25 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I plan to use the carbs off of the old crossram the carbs have a different jet in each corner what would be a good place to start on jet .060 440 12.5:1 sr cnc heads .620 flat tappet not too familiar with afb/edelbrock carbs
Re: Indy 440-25 cross ram [Re: biff426] #446125
08/23/09 09:51 AM
08/23/09 09:51 AM
BigFish69 Offline
BigFish69  Offline
Look at the wilson 333221 burst plate about 75.00 summit has it.
Tom
Re: Indy 440-25 cross ram [Re: dvw] #446126
08/24/09 10:55 AM
08/24/09 10:55 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Doug
Right on. If you do that you will never blow a manifold apart. I ran that manifold for a couple years, no blow off valves.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Indy 440-25 cross ram [Re: HemiDart68] #446127
08/24/09 10:58 AM
08/24/09 10:58 AM
I should know better than to even ask but is something like that streetable?
Re: Indy 440-25 cross ram [Re: HemiDart68] #446128
08/24/09 11:22 AM
08/24/09 11:22 AM
Aurora, Oh.
Aurora, Oh.
Doug
I disagree... I was at 131 a couple of years ago for the CC Event Race and that is where I blew my 2nd intake. I started the car and was "driving" through the pits on Friday to go get teched in and while "driving" the intake exploded. There were many Moparts members there that saw this happen and even Nick Wilson from Compuflow saw it happen. Get the blow off valves
Russ
Re: Indy 440-25 cross ram [Re: max_maniac] #446129
08/24/09 05:32 PM
08/24/09 05:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Doug
I disagree... I was at 131 a couple of years ago for the CC Event Race and that is where I blew my 2nd intake.{HOW DID THAT TASTE??} I started the car and was "driving" through the pits on Friday to go get teched in and while "driving" the intake exploded. There were many Moparts members there that saw this happen and even Nick Wilson from Compuflow saw it happen. Get the blow off valves ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, The only way that would blow up is on initial start up without crackin' the throttle plates,,,,,,,or if it were drippin' fuel while idling and loaded up and sneezes and KABOOM
Re: Indy 440-25 cross ram [Re: hemi-itis] #446130
08/24/09 06:28 PM
08/24/09 06:28 PM
Doug
never had an explosion on both of mine.
its all in the jetting. no expansion valves here either.
and yes if properly tuned, they are streetable.
Re: Indy 440-25 cross ram #446131
08/24/09 06:29 PM
08/24/09 06:29 PM
if properly tuned these intakes are awesome.
Re: Indy 440-25 cross ram #446132
08/24/09 07:48 PM
08/24/09 07:48 PM
just put the blow off valves on. if anything its just a little extra insurance. doesnt hurt anything
Casey
Re: Indy 440-25 cross ram #446133
08/24/09 08:36 PM
08/24/09 08:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree they don't hurt anything. I'm just to cheap to spend $75 x 2 for them. Why would these manifolds be any more prone to exploding than any other large open plenum style? I did blow up a Hemi cross ram while driving in the pits. It hung a intake valve wide open and BOOM. It sent one of the original A990 carbs into the original A990 scoop and stuck it there. The bowl vents pierced the scoop like a paper punch. Blow offs are like any other insurance item. Pay your money or take your chances.
Doug
Re: Indy 440-25 cross ram [Re: dvw] #446134
08/24/09 09:16 PM
08/24/09 09:16 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Dripping fuel or getting crazy pumping it upon start up is an issue with these intakes - cause they do like to go boom. Look for fuel dripping it can be a high float etc.. but one cause of dripping fuel is from these new edelbrock carbs. If you ever backfired an newer Eddy carb you have a better than 50% chance it will drip. it's an issue with the casting method that was not seen on the original carters - look at primary from underneath mainly around the idle air bleed screw for small cracks or worse yet missing material. The other issue is the screws on the throttle paltes coming loose and causing the throttle plate to mis-align and cause a high idle.
Re: Indy 440-25 cross ram [Re: hemi-itis] #446135
08/24/09 09:32 PM
08/24/09 09:32 PM
Aurora, Oh.
Aurora, Oh.
Doug
I disagree... I was at 131 a couple of years ago for the CC Event Race and that is where I blew my 2nd intake.{HOW DID THAT TASTE??} I started the car and was "driving" through the pits on Friday to go get teched in and while "driving" the intake exploded. There were many Moparts members there that saw this happen and even Nick Wilson from Compuflow saw it happen. Get the blow off valves ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, The only way that would blow up is on initial start up without crackin' the throttle plates ,,,,,,,or if it were drippin' fuel while idling and loaded up and sneezes and KABOOM
I agree with your statement about the drippin fuel - I also know of many others that have had the issue while driving. I know there are many that have never had an issue and that is great but maybe one day just when you are ready to go to the final round and she blows ---- then you find the carb issue that was hidden for a while and now it just cost you alot more money. Not every car will be perfect every time - get the blow offs
Russ
Re: Indy 440-25 cross ram [Re: max_maniac] #446136
08/25/09 01:26 PM
08/25/09 01:26 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Would you drive your car with out insurance?It's like anything else you don't need till it happens to you.If you don't want to spend the dollars,you can make them yourself very easily.
Re: Indy 440-25 cross ram [Re: B G Racing] #446137
08/25/09 01:33 PM
08/25/09 01:33 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I went way cheap on my cross ram. Just got some plastic plugs from McMaster Carr and submerged a few in gas for a few days. Found a couple that didn't warp and melt. Then I drilled a few holes in the intake and siliconed the plugs in there.
I've "sneezed" a couple times. Nothing major. Everytime, it pops those things out! I either find them or replace them with others that I keep in the glovebox! I've got about $7 invested in this!
Re: Indy 440-25 cross ram [Re: LAR_414] #446138
08/25/09 02:17 PM
08/25/09 02:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That's just what I would expect from you
Re: Indy 440-25 cross ram [Re: B G Racing] #446139
08/25/09 02:35 PM
08/25/09 02:35 PM
LAR_414 Offline
LAR_414  Offline
Re: Indy 440-25 cross ram [Re: LAR_414] #446140
08/25/09 02:37 PM
08/25/09 02:37 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
[/q
