Re: et help
[Re: fowl play]
#446073
08/22/09 02:42 PM
08/22/09 02:42 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
what to do to get the best out of my car? i have a dart with a 414 small block b1 heads, 13 to 1 comp. 620 mopar cam. 950 hp carb. 4800 dynamic conv.in a 727. 4.56's ladder bars and coilovers, qa1's. 10.5 by 31 tires car runs 10.6-10.7 at 3800' air in good air 10.44- 10 55. should it run faster?2800 with me in it. most everyone one here with a similar combo is quicker. where should i start to adjust, or make changes? thanks
what intake, what is done to the heads, and what are the cam specs exactly??
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: et help
[Re: fowl play]
#446075
08/22/09 05:22 PM
08/22/09 05:22 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Change the intake first Any high rise single plane will work better and be quicker, IMO
Re: et help
[Re: fowl play]
#446076
08/22/09 07:14 PM
08/22/09 07:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can you give us a time slip Or all the numbers to see where its lagging... how many revs do you take it to and what do you launch at(rpm) and shift at
Re: et help
[Re: fowl play]
#446079
08/22/09 09:14 PM
08/22/09 09:14 PM
MR_P_BODY
jn responce to the intake. koffel's said they tested a bunch of intakes and the torquer made the most power, i don't know. also mr p body i am leaving at 3500 and shifting at 6000.
Can you give the cam specs at .050.... and what the cam is installed at(centerline)... thats some REAL low rpm's to be shifting at unless its a all torque engine
Re: et help
[Re: fowl play]
#446081
08/22/09 09:55 PM
08/22/09 09:55 PM
MR_P_BODY
mopar performance doesn't give specs at 50 and i do notknow what centerline it is installed at. tje motor made 565hp at 6500 and 550 fi lb torque at 4800. i am wonering if there is more with this combo or not. best at norwalk 10.44at 126 with old convertor. thanks
Well if it makes peak power at 6500 why are you shifting at 6000
Re: et help
[Re: MR_P_BODY]
#446082
08/22/09 11:13 PM
08/22/09 11:13 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Mr.P, Mopar advertises that cam's duration @.050 as 275. I think in real world measurements they are 282 @.050. It also has a lobe separation of 106,might be part of the problem with his stroker?
Re: et help
[Re: Dunnuck Racing]
#446083
08/22/09 11:38 PM
08/22/09 11:38 PM
MR_P_BODY
If it has a duration that high he needs to really step up the revs.... but the intake and probably the carb are holding it back... if he would post the time slip it would help alot....with the 106 LSA he should have all sorts of low end power and have some decent 60' times
Re: et help
[Re: MR_P_BODY]
#446084
08/23/09 11:19 AM
08/23/09 11:19 AM
Posts: 69 W.Va
fowl play
W.Va
mr p body here are some number from fall at norwalk. some the best.60' 1.464 330 4.269 1/8 6.652 @102.66 1000 8.733 1/4 10.52@124.91 60' 1.473 330 4.283 1/8 6.671@102.75 1000 8.759 1/4 10.549@ 125.46 these numbers are with the old 4200 t/a convertor just before it went south. this was also in good air. i am looking to improve what i have not to change too much. thanks for your help.
Re: et help
[Re: fowl play]
#446085
08/23/09 11:29 AM
08/23/09 11:29 AM
MR_P_BODY
mr p body here are some number from fall at norwalk. some the best.60' 1.464 330 4.269 1/8 6.652 @102.66 1000 8.733 1/4 [Email]10.52@124.91[/Email] 60' 1.473 330 4.283 1/8 [Email]6.671@102.75[/Email] 1000 8.759 1/4 10.549@ 125.46 these numbers are with the old 4200 t/a convertor just before it went south. this was also in good air. i am looking to improve what i have not to change too much. thanks for your help.
By chance, you arent using MP valve springs are you? The 60' is soft for a 2800# car.... but the whole pass is soft
Re: et help
[Re: fowl play]
#446087
08/23/09 12:03 PM
08/23/09 12:03 PM
MR_P_BODY
i don't know for sure about the valve springs i will check. why are they bad, soft ,not enough pressure or what? thanks.
Way under pressure for what you really need. I ran them 1 time(full season) and from the moment I let go of the trans brake I went to valve float for the whole run... never broke them and thankfully they went into coil bind before the valves hit the pistons.... I figured they were just worn out but when I checked the new springs to replace the old ones... they were identical pressures.... junk
Re: et help
[Re: MR_P_BODY]
#446088
08/23/09 12:04 PM
08/23/09 12:04 PM
Posts: 705 Michigan
Hemiroid
If it were me, I would be changing the cam, intake, rear gear, carb, and converter My combo would have been a solid roller 280ish @ .050 .700ish lift, single plane with a 1050 dom, 5.13 gear and around 5500 stall and let her eat . With that being said, the things that in my mind absolutely need to be changed are the cam and intake. There are lots of great solid shelf cams that are way better then the .620. The intake is really hurting your combo as well and I believe it should be changed. You're geared perfectly for and have the right converter for a big block stroker, unfortunately you have a smallblock!! As Mr. P stated, you need to rpm the motor to reach it's true potential. Shifting it at 6000 isn't doing that.
Re: et help
[Re: S/ST 3040]
#446090
08/23/09 12:22 PM
08/23/09 12:22 PM
Posts: 705 Michigan
Hemiroid
At 2800 lbs you should be well into the nines.
4.56 and 31" tire will work good. I think the cam is in need of improvement,
5300-5400 for converter would work better too.
Opps, misread it. Thought it said 33's. I still would have went 4.88 even with 31's. The 4.56 will suffice, but the converter is light, the intake is all wrong and the cam is so 20 years ago
