Spot weld cutter #445486
08/21/09 09:57 PM
08/21/09 09:57 PM
KS
68SportSatvert Offline OP
KS
Anyone try one of the new style spot weld cutters that is an air drill? I'm wondering if they work any better than the roto broach/Blair style cutters.
Re: Spot weld cutter [Re: 68SportSatvert] #445487
08/22/09 12:53 AM
08/22/09 12:53 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I'm not sure what the "new style" is? Got a web address or picture?
Re: Spot weld cutter [Re: Lefty] #445488
08/22/09 08:17 AM
08/22/09 08:17 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
ive never seen or used anything better than a rotot broach,,,are you talking about the drill that has a c clamp on it and its all self contained? iirc thats huge money, ive sen it never would shellout the cash for it to try, the rotobroach in a low rpm drill works great!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Spot weld cutter [Re: pnypwr] #445489
08/22/09 08:44 AM
08/22/09 08:44 AM
KS
KS
Re: Spot weld cutter [Re: 68SportSatvert] #445490
08/22/09 08:55 AM
08/22/09 08:55 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
ive used that style cutter before without much luck, i like that you can set the plunge depth tho, put a rotobroach in that and you would have a serious tool!
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Spot weld cutter [Re: pnypwr] #445491
08/23/09 02:19 AM
08/23/09 02:19 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
I like the rotabroach style much better. The only bad part about the Blair cutters is they are brittle and around $9 each or more. Lately I've been using another annular cutter, from Harbor Freight of all places, and it works excellent. Around $4 with a two sided cutter and adjustable tension centering pin. Much less brittle and the cutter even works with a couple teeth broken off.
HF cutter bit
Re: Spot weld cutter [Re: nomore65BelvJim] #445492
08/23/09 02:27 AM
08/23/09 02:27 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
Still Broke
Re: Spot weld cutter [Re: 68SportSatvert] #445493
08/23/09 01:34 PM
08/23/09 01:34 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
If you can sharpen a drill,make it look like this and you will never use one of those cheesy cutters again. Mike
Re: Spot weld cutter [Re: mkdart] #445494
08/24/09 10:41 AM
08/24/09 10:41 AM
nothing "cheesy" about an annular cutter, its a purpose designed tool. I dont like having to modify a drill bit to "make it work" for a job it wasnt intended for. The annular cutter only removes a ring of steel so it cuts faster and cleaner. Its like a hole saw as opposed to a drill. The way your dill bit tip is cut makes it much more likely to "wander" than the annular cutters.
By all means use what you like, but I've found that the cutters work 100x better for me
Re: Spot weld cutter [Re: nomore65BelvJim] #445495
08/24/09 01:33 PM
08/24/09 01:33 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I picked one of those up the other day...... now my favorite spot weld cutter! I was tired of breaking a tooth off of the Blair cutter and the bit would be done. Now I just have to get over my brother-in-law making fun of me for getting stuff at Harbor Frieght.....
