71 E Body Wiper Motor ?? For Jules perhaps? #445409
08/21/09 08:48 PM
08/21/09 08:48 PM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
I have a 71 Chally with the variable wiper motor PN 3431077. My problem is, when I turn on the key, i get a major draw of current from the wiper motor (in the off position). Also, when I turn on the switch, it only goes one speed and never parks correctly. I've tried another switch with the same result.
Is it just that I need to rebuild the unit or am I experiencing some other phenomenon I'm unaware of? Thanks for any help guys.
1967 GTX 440 Auto Tribute
1968 Charger 440 Auto
1968 D100 318 Auto Stepside - Daily Driver
1974 Road Runner 318 Auto
1954 Coronet 2dr Hemi Std with O/D
73 Road Runner 360/4spd Sassy Grass - sold
71 Challenger R/T Clone 383 MAG Auto - sold
Re: 71 E Body Wiper Motor ?? For Jules perhaps? [Re: 67G2THEX] #445410
08/22/09 12:17 AM
08/22/09 12:17 AM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
Re: 71 E Body Wiper Motor ?? For Jules perhaps? [Re: 67G2THEX] #445411
08/22/09 07:50 AM
08/22/09 07:50 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
The problem 98% of the time is with the switch but try this first.
Disconnect the linkage from the motor and try the switch again.
If you get the same result then there is a problem with the switch or
a bad ground. Make sure the motor and the switch is properly grounded.
Make sure all your terminals have good clean contacts. If you tried another
switch did you ground the housing of the switch when you tried the test?
Jules
