Need advice on removing wrist pin locks!!!! #444988
08/21/09 09:47 AM
08/21/09 09:47 AM
Sweet Home Alabama
MRMOPAR622 Offline OP
Sweet Home Alabama
I have a set of Wiseco pistons on BME rods and I need to remove the rods. They have the CS25 pin retainers,Retainer Width/Wire Diameter .042.And I am not sure how to remove them. It looks like they are wrapped about 4 rounds. The only way I see to remove them is to take a small screw driver and pry the outer wire out and just unwrap them.
Is this the correct way to remove them? I do not want to ruin them. Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Need advice on removing wrist pin locks!!!! [Re: MRMOPAR622] #444989
08/21/09 09:50 AM
08/21/09 09:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats pretty much how I do it... I use a small pick
and wind them out
Re: Need advice on removing wrist pin locks!!!! [Re: MR_P_BODY] #444990
08/21/09 01:57 PM
08/21/09 01:57 PM
Sweet Home Alabama
Sweet Home Alabama
Thanks MR_P_BODY, was just not sure if that was the right way or not. I bet its a lots harder to get them back in than out. Thanks again
Re: Need advice on removing wrist pin locks!!!! [Re: MRMOPAR622] #444991
08/21/09 02:06 PM
08/21/09 02:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually they go in fairly easy
