Gas tank venting problem - help! #444910
08/21/09 08:30 AM
08/21/09 08:30 AM
middle of the country
aar1 Offline OP
aar1  Offline OP
I just discovered that my gas tank DOES NOT have any vents in it. There is no nipple on the tank to connect the vent hose to. The tank has a vented gas cap on it. The tank builds up a lot of positive pressure so when you remove the cap, there is a rush of vapors out of the tank.
What are my options to correct this? It’s actually bad enough to push gas out around the cap if I fill the car up then it sets in the sun. Is there a different cap I could use or do I just need to put in a correct vented tank? If it matters, this is for a '70 cuda.
Thanks!!
Re: Gas tank venting problem - help! [Re: aar1] #444911
08/21/09 08:44 AM
08/21/09 08:44 AM
Tecumseh, Ontario, Canada
Moparnut Offline
Moparnut  Offline
Your gas cap is not a vented type as it seals the tank. If you can located a vented cap then this should correct your issue. This will allow the pressure to escape.
Re: Gas tank venting problem - help! [Re: Moparnut] #444912
08/21/09 08:48 AM
08/21/09 08:48 AM
aar1 Offline OP
aar1  Offline OP
The gas cap is a vented type, at least that is what is stamped on it, unless it's not functioning. But isn't a vented gas cap like a check valve, only letting air in but not out? Is there a way to test a gas cap?
Re: Gas tank venting problem - help! [Re: aar1] #444913
08/21/09 09:05 AM
08/21/09 09:05 AM
Moparnut Offline
Moparnut  Offline
I am assuming this is a new tank that was installed when the car was restored or tank replaced. You can add a vent but would have to drop the tank and empty to put in a vent. I would not do this in the car for fear of fire.
I had a buddy do this and he dropped the tank and welded a nipple on the tank. (Chev )
I have also seen some people drill a very small hole in the cap to allow the release of pressure. Not my way of fixing a problem but have seen it done.
I don't know where you can have the tank cap checked but I think there was a device that the old mechanics used to check them similar to what they are doing now to check gas caps for emission testing.
Re: Gas tank venting problem - help! [Re: Moparnut] #444914
08/21/09 09:24 AM
08/21/09 09:24 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Not in my case it doesn't with a vented cap! I'm sure the 70 cuda has alot more vent lines than my a100 and I can't put more than a 1/3 of a tank of gas before it starts happening to me. I think alot of it has to do with this reformulated crap thaey call gas. In the meantime, The struggle continues!
Re: Gas tank venting problem - help! [Re: aar1] #444915
08/21/09 09:35 AM
08/21/09 09:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are you sure? I'm not familer with reg 70 tanks, but I'm sure there are vent nipples on the tank when it was made, no matter what year it was built for.
Re: Gas tank venting problem - help! [Re: Challenger 1] #444916
08/21/09 09:50 AM
08/21/09 09:50 AM
aar1 Offline OP
aar1  Offline OP
Yes........ there are no vent nipples on the tank. It IS NOT an original tank. A previous owner bought it from Year One about 15 years ago.
Re: Gas tank venting problem - help! [Re: aar1] #444917
08/21/09 09:56 AM
08/21/09 09:56 AM
Cincinnati, Ohio
Cincinnati, Ohio
Does it fit right? I'd get a correct tank for your 70 cuda and hook everything up like it was when new.
Re: Gas tank venting problem - help! [Re: Challenger 1] #444918
08/21/09 10:03 AM
08/21/09 10:03 AM
aar1 Offline OP
aar1  Offline OP
The fit was fine, just no provision for venting
If I do end up getting a "correct" tank, where's the best place to get them? Do they all come from the same chinese boat or are there any tanks out there that are better quality?
Re: Gas tank venting problem - help! [Re: aar1] #444919
08/21/09 10:12 AM
08/21/09 10:12 AM
Cincinnati, Ohio
Cincinnati, Ohio
E bay is one of the better choices I think. You might want to remove your tank and take a good look, because I'm thinking no one would make a tank without venting provisions.
Re: Gas tank venting problem - help! [Re: aar1] #444920
08/21/09 12:06 PM
08/21/09 12:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Quanta makes the best repro tanks.........
Re: Gas tank venting problem - help! [Re: DAYCLONA] #444921
08/21/09 12:37 PM
08/21/09 12:37 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Take out the filler neck and add a nipple from 1/4 steel tube and make your own vent line.
Re: Gas tank venting problem - help! [Re: aar1] #444922
08/21/09 01:46 PM
08/21/09 01:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Did you look on the front of the tank for vent nipples?
Re: Gas tank venting problem - help! [Re: Snoopy] #444923
08/21/09 01:55 PM
08/21/09 01:55 PM
aar1 Offline OP
aar1  Offline OP
Looked and felt up there but couldn't find anything Also.... if there were a vent nipple somewhere on the tank but the rubber vent hose just didn't get hooked up, the tank would not build up positive pressure, would it? The pressure would be released via the nipple and I would be smelling gas fumes, correct?
Re: Gas tank venting problem - help! [Re: Rollin Hand] #444924
08/21/09 02:08 PM
08/21/09 02:08 PM
Clarkston, MI
2
2RTSE Offline
2RTSE  Offline
Clarkston, MI
Just went through this nightmare on my 70 Challenger. Found out that 70's have a nipple on the top of the filler tube inside the trunk which gets vented through the trunk floor into the right frame rail. Drilling a hole in a vented gas cap will vent the tank but also allow gas to spill out. I know!!
What you have is a filler tube from a 72-74 ebody which has a totally different venting system.
Re: Gas tank venting problem - help! [Re: 2RTSE] #444925
08/21/09 02:18 PM
08/21/09 02:18 PM
aar1 Offline OP
aar1  Offline OP
This is for a cuda, so there will not be a vent nipple on the filler tube. That is only on the challenger since it's filler tube is over on the right side. Cuda is behind the license plate.
Re: Gas tank venting problem - help! [Re: aar1] #444926
08/21/09 03:31 PM
08/21/09 03:31 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
the cuda vent should be on the passenger side top edge. I believe there is a slanted flat middle section (vs a rounded 90 degree top edge). a small nipple with a tiny hole in it. no vent on the filler neck
Re: Gas tank venting problem - help! [Re: aarcuda] #444927
08/21/09 09:29 PM
08/21/09 09:29 PM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
and it's hiding behind the heat sheild. Goes up through the trunk and back through the rear frame rail.
Re: Gas tank venting problem - help! [Re: solarguy] #444928
08/22/09 12:04 AM
08/22/09 12:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
A vented cap will vent all the time. You must have the newer cap that only vents when so much pressure or vacum is built up. Get a cap for something like a 66 Coronet or something along that line and you will be fine. Thats what I did on my sons 72 Dart. Ron
Re: Gas tank venting problem - help! [Re: aar1] #444929
08/22/09 12:15 AM
08/22/09 12:15 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
There are 3 basic type of gas caps:
"NOT VENTED" - As the name implies. Seals tight. Used on cars with another method of venting the tank.
"VENTED" - basically, open to the atmosphere - a pinhole, etc. I suppose this could somehow get clogged or plugged, but this is hard to fathom.
"PRESSURE-VACUUM" - This type has a small check valve built in, allows unrestricted flow of make-up air in; vents to the atmosphere at a predetermined pressure point.
I have found that this last type covers a multitude of sins (venting problems, raw fuel spillage, etc.)
Rick E.
