offset intake rockers for 915 SB heads ?? #444772
08/21/09 12:16 AM
08/21/09 12:16 AM
merrill, wisconsin
V
voigtspeed Offline OP
V
merrill, wisconsin
I want to open up pushrod pinch for a stock head class can i use W2/W5 rockers or do i need T/A's is the offset different??
I do not have either one now anybody have some for sale???
They are for my 16 year old sons low buck 340 project.
thanks jim
ACCELERATION SPECIALIST
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444773
08/21/09 12:44 AM
08/21/09 12:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you don't have T/A heads what advantage do you feel offset rockers would give you??? Unless you intend to furnace braze the original pushrod tube closed...
Re: offset intake rockers for 915 SB heads ?? [Re: 1_WILD_RT] #444774
08/21/09 01:32 AM
08/21/09 01:32 AM
merrill, wisconsin
V
V
merrill, wisconsin
Closing it up is the plan that is no problem.
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444775
08/21/09 07:20 AM
08/21/09 07:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
What is the purpose?? Low buck??
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444776
08/21/09 08:40 AM
08/21/09 08:40 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
All of the W-2 rockers, I've tried, have too much pivot length, leaving
the roller hanging off the far side of the valve. I haven't tried them
all, so there's a slim chance one of the manufacturers W-2s would work.
You have some options though..........long valves and machine pedistals
exactly like a W-2 head.
I think cheapstreet used an INDY rocker from some other engine.
I'd just call Harland Sharp and get their T/A rockers, myself.
There is always the custom route but, doubt you want to spend big $$$$$
since you said, "low buck".
Re: offset intake rockers for 915 SB heads ?? [Re: S/ST 3040] #444777
08/22/09 02:36 AM
08/22/09 02:36 AM
merrill, wisconsin
V
V
merrill, wisconsin
Thanks for the input.
just using some old parts i have around for my sons ice drag car.
current class record is 7.37 seconds @ 100.22 m.p.h. on 660 feet of ice.
Held by a cleavland headed ford.
I would like that to change.
Being only @ 340 cubes and restricted to stock head castings i need to do all i can to the heads I will be the smallest motor in the class.
I have a 13.0 to one shortblock with a good crank, alluminum rods and a .630 roller, milodon oil system and gear drive all practicaly new from the 70's. allso a tunnel ram and some 2" headers
have had all these parts for some time and feel the low tourqe high winder may be an asset on the ice .
I could easily put together a big block but the weight and extra tourqe will just make me spin more .
Thats why its low buck just using up some parts to get my son racing.............
check out our website we made car craft in august our track record is 5.5 seconds @ 140!!!
www.merrillicedrags.com
thanks jim
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444778
08/22/09 02:39 AM
08/22/09 02:39 AM
merrill, wisconsin
V
V
merrill, wisconsin
What to do in january!!!!!!!!!!!!!!
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444779
08/22/09 03:32 AM
08/22/09 03:32 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Holy crap!!!!!
You guys race on ice!!!!
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444780
08/22/09 03:34 AM
08/22/09 03:34 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Gritzmachers got a set of 810 W2 castings, paint them and put them on there. No one will know the difference up there in the sticks
SDG Motorsports
Re: offset intake rockers for 915 SB heads ?? [Re: voigtspeed] #444781
08/22/09 04:35 AM
08/22/09 04:35 AM
sweden
sshemi Offline
sshemi  Offline
sweden
thanks jim
I was thinking of useing the hughes rockers for the bb victor heads. they are 0.6" offset.
Dont know if it will work though.
