5/8 fuel line #444481
08/20/09 07:36 PM
08/20/09 07:36 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Ok so I'm trying to finish up the fuel lines, when bang I'm stuck again. How am I suppose to flar the line for tube nut... Mine only goes to 1/2.. What to do, is there any other way to do it..
Re: 5/8 fuel line [Re: 70dusterjohn] #444482
08/20/09 07:43 PM
08/20/09 07:43 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Jegs sells their full line of fuel line components cheap. I'd use their compression style fitting... no flaring needed.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: 5/8 fuel line [Re: flatlinedude] #444483
08/20/09 07:45 PM
08/20/09 07:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used compression fittings on mine
Re: 5/8 fuel line [Re: WILD BILL] #444484
08/20/09 08:13 PM
08/20/09 08:13 PM
Deerfield, Ohio
Deerfield, Ohio
So do I just go buy a compression fitting and still use the tube nut that I got, cause I got that push tight line with fittings.
Re: 5/8 fuel line [Re: 70dusterjohn] #444485
08/20/09 08:24 PM
08/20/09 08:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The ones I used adapt the hard line to an AN fitting. Just screw the AN right on.
Re: 5/8 fuel line [Re: WILD BILL] #444486
08/20/09 08:30 PM
08/20/09 08:30 PM
Hemiroid Offline
Hemiroid  Offline
Hmm,I wonder if that only work with aluminum line?
Re: 5/8 fuel line [Re: Hemiroid] #444487
08/20/09 08:33 PM
08/20/09 08:33 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Never used them on anything but aluminum lines.
Re: 5/8 fuel line [Re: WILD BILL] #444488
08/20/09 08:40 PM
08/20/09 08:40 PM
Hemiroid Offline
Hemiroid  Offline
Me too. The ferral probably has to be used with mallable lines so it can pinch it to hang on to it. I have a 3/8 steel line on my X that I need to come off of with AN into my regulator. Can't stand looking at rubber hose and clamps, even though it works
Re: 5/8 fuel line [Re: Hemiroid] #444489
08/20/09 08:46 PM
08/20/09 08:46 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
you can use compression fittings on steel lines with no problem.
Re: 5/8 fuel line [Re: rowin4] #444490
08/20/09 08:50 PM
08/20/09 08:50 PM
Hemiroid Offline
Hemiroid  Offline
You're right!! What the hell am I thinking about. I've only used them 100 times on steel trans lines and such. Brain cramp!!
Re: 5/8 fuel line [Re: 70dusterjohn] #444491
08/20/09 10:20 PM
08/20/09 10:20 PM
I have used a 45 degree flaring tool on aluminum fuel lines, I didn't flare it all the way to 45 degrees to make it work with the 37.5 degree fittings. I ended up later buying a Parker brands AN flaring tool several years ago when I owned and maintained my own airpalne, the Feds didn't like anything non FAA aproved, procedures, tools or parts going onto a FAA certified airpalne
Re: 5/8 fuel line [Re: WILD BILL] #444492
08/21/09 10:39 AM
08/21/09 10:39 AM
Deerfield, Ohio
Deerfield, Ohio
I had compression fittings on there before and they leaked all the time. I just don't want to have that problem again.. And anytime that you would bumb the line it would start leaking.. just don't want any problems..
Re: 5/8 fuel line [Re: 70dusterjohn] #444493
08/21/09 10:44 AM
08/21/09 10:44 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
WOW
I never had any troubles with them
Re: 5/8 fuel line [Re: WILD BILL] #444494
08/21/09 10:48 AM
08/21/09 10:48 AM
Deerfield, Ohio
Deerfield, Ohio
WOW
Maybe its me.. Well I guess I'll try it again.. if not I'll just them in there... I just don't see anyother way..
Re: 5/8 fuel line [Re: 70dusterjohn] #444495
08/21/09 03:42 PM
08/21/09 03:42 PM
San Diego
64dartsb Offline
64dartsb  Offline
San Diego
I've heard of people heating it up first with a torch so it doesn't come out messed up near the seam, if it has one
if your dreaming of your car then it's your dream car....
Re: 5/8 fuel line [Re: 64dartsb] #444496
08/21/09 06:53 PM
08/21/09 06:53 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Summit part numbers
EAR-165010ERL 5/8 tube to -10 male
EAR-165110ERL 5/8 tube to -10 female swivel
I'm Gumby dammit!
