Re: 5/8 fuel line
[Re: 70dusterjohn]
#444482
08/20/09 07:43 PM
08/20/09 07:43 PM
Posts: 682 Land of Lost
flatlinedude
No pulse
No pulse
Land of Lost
Jegs sells their full line of fuel line components cheap. I'd use their compression style fitting... no flaring needed.
Carol: "Wow! He's really fast, isn't he?!"
John: "Yeah... but he's stupid."
Re: 5/8 fuel line
[Re: flatlinedude]
#444483
08/20/09 07:45 PM
08/20/09 07:45 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used compression fittings on mine
Re: 5/8 fuel line
[Re: WILD BILL]
#444486
08/20/09 08:30 PM
08/20/09 08:30 PM
Posts: 705 Michigan
Hemiroid
The ones I used adapt the hard line to an AN fitting. Just screw the AN right on.
Hmm,I wonder if that only work with aluminum line?
Re: 5/8 fuel line
[Re: Hemiroid]
#444487
08/20/09 08:33 PM
08/20/09 08:33 PM
WILD BILL
BROOK PARK, OH
Never used them on anything but aluminum lines.
Re: 5/8 fuel line
[Re: WILD BILL]
#444488
08/20/09 08:40 PM
08/20/09 08:40 PM
Posts: 705 Michigan
Hemiroid
Me too. The ferral probably has to be used with mallable lines so it can pinch it to hang on to it. I have a 3/8 steel line on my X that I need to come off of with AN into my regulator. Can't stand looking at rubber hose and clamps, even though it works
Re: 5/8 fuel line
[Re: rowin4]
#444490
08/20/09 08:50 PM
08/20/09 08:50 PM
Posts: 705 Michigan
Hemiroid
you can use compression fittings on steel lines with no problem.
You're right!! What the hell am I thinking about. I've only used them 100 times on steel trans lines and such. Brain cramp!!
Re: 5/8 fuel line
[Re: WILD BILL]
#444492
08/21/09 10:39 AM
08/21/09 10:39 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I had compression fittings on there before and they leaked all the time. I just don't want to have that problem again.. And anytime that you would bumb the line it would start leaking.. just don't want any problems..
Re: 5/8 fuel line
[Re: 70dusterjohn]
#444493
08/21/09 10:44 AM
08/21/09 10:44 AM
WILD BILL
BROOK PARK, OH
WOW
I never had any troubles with them
Re: 5/8 fuel line
[Re: WILD BILL]
#444494
08/21/09 10:48 AM
08/21/09 10:48 AM
70dusterjohn
Deerfield, Ohio
WOW
Maybe its me.. Well I guess I'll try it again.. if not I'll just them in there... I just don't see anyother way..
Re: 5/8 fuel line
[Re: 70dusterjohn]
#444495
08/21/09 03:42 PM
08/21/09 03:42 PM
Posts: 363 San Diego
64dartsb
San Diego
I've heard of people heating it up first with a torch so it doesn't come out messed up near the seam, if it has one
if your dreaming of your car then it's your dream car....
