Hedmen Street Hedders #444155
08/20/09 10:05 AM
08/20/09 10:05 AM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Hey guys i recently purchased some $150.00 hedmen hedders from jegs and noticed they had the ball type flange connection, the collectors are part of the header and are 3". I was looking at http://www.summitracing.com/parts/PYE-XVX13/ and was wondering if they would hook up to this type of connection? and if they obstruct anything on a 68 b-body? Thanks Guys
Re: Hedmen Street Hedders [Re: 440_ci] #444156
08/20/09 06:17 PM
08/20/09 06:17 PM
IA
landon1 Offline
landon1  Offline
IA
i'm not sure on the new collector...i have hedman street headers on my 71, but they are the older variety with standard 3" collectors.
i think they're called "ball and socket", so i'd assume you would need a "socket" adapter to put on your mid pipes/extensions
'71 Satellite Sebring 440
Re: Hedmen Street Hedders [Re: 440_ci] #444157
08/20/09 06:40 PM
08/20/09 06:40 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Agree with above.
Seems like you "could" use adapters and/or prep it and take it to a local muffler shop to complete (unless you know how to weld / have access to the equipment.)
Re: Hedmen Street Hedders [Re: D_C] #444158
08/20/09 07:18 PM
08/20/09 07:18 PM
Kirkland, Washington
Pacnorthcuda Offline
I have the ball and sockets too. You NEED the socket adapters, Jegs/Summit sells them. You or your exhaust man can then install.
Re: Hedmen Street Hedders [Re: Pacnorthcuda] #444159
08/20/09 09:18 PM
08/20/09 09:18 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Didn't your Hedman hedders come with the flared socket halves? Both sets I've purchased came with them.
Re: Hedmen Street Hedders [Re: In_The_Pink] #444160
08/20/09 09:22 PM
08/20/09 09:22 PM
Hell no---I wish!!! I was kinda torqued cuz the picture from Summit showed the standard flat (gasket) flange AND I sent them directly to Jet-Hot for $300 of Sterling ceramic. Then I get em and they're ball and socket. I then bought the adpaters. (Maybe they DID come with, and Jet-Hot never forwarded them to me????????????????????_ Never thought about that!!!!) Hmmmmmmmmm
Re: Hedmen Street Hedders [Re: Pacnorthcuda] #444161
08/20/09 09:48 PM
08/20/09 09:48 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I just bought a set (from Summit) and they came with the halves, yep I'd call Jet Hot.
