Re: 383 build - opinions wanted
[Re: cudadoug]
#443377
08/19/09 10:11 PM
08/19/09 10:11 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I'd use the Performer RPM if it's a street deal.
For CR, 10.7 might be a little high for pump gas, depending on what's available in your area. 10.2 might bt too much...it all depends on the gas, but that's where I'd start.
On the choice on the intake and the compression ratio, I would shoot for no more than a actual 9:75 to 1 compression ratio with todays pump swill I have a iron headed 446 RB motor that will ping on the local premium gas if I lean it down so it is at 14,2 AFR or leaner at part throttle with 34 degrees timing and medium heat range spark plug It is a true 9.46 to 1 mechanical compression ratio with a Eddy Performer RPM intake and a Holley #4781-7 850 DP carb This motor is not a true quench motor due to the 906 combustion chamber size and the late head casting
[Re: Cab_Burge]
#443378
08/19/09 11:01 PM
08/19/09 11:01 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree on using the Performer RPM on it for a mostly street car. My sons .030 over 400 is close to your build. He uses Eddy RPM heads with 10.6 comp but with the aluminum heads and the MP .557 cam it runs fine on 92 pump. His 400 is in a 72 Dart with 3.91's and he uses the Performer RPM with a 750 DP. His is a street car and it has the Dynamic 9.5 converter. It has run 11.40's in good air at almost 3600 lbs with him in the car. Sounds like you have a nice combo but I agree that without quench you are pushing it with that cam and 10.7 comp using iron heads. Good luck , Ron
