Page 5 of 6 1 2 3 4 5 6
Re: Best Intake for a Street 383 [Re: Freiburger] #44310
08/29/07 12:31 PM
08/29/07 12:31 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Dave,
Could you post the Street Dominator and the DP4B torque and HP curves?
Thanks,
Ron
Re: Best Intake for a Street 383 [Re: Freiburger] #44311
08/29/07 12:34 PM
08/29/07 12:34 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
They all made peak torque around 4,000 and peak hp around 5,900. Sorry, I can't type 15 different full curves onto the message board. Maybe one or two. What are you interested in?
DF
I didnt see this post
How about the Street Dominator (Single plane)
versus the Performer or DP4B (Dual plane)
Would like to see the difference down low versus say 5500 - 5800 rpms
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Best Intake for a Street 383 [Re: Ronnman] #44312
08/29/07 12:34 PM
08/29/07 12:34 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Excellent info dave. Thanks for posting this. I'll be running a Performer on my 400 due to low hood clearnace...doesn't look like it gives up that much to an RPM (with your combo). That's good to know!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Best Intake for a Street 383 [Re: DynoDave] #44313
08/29/07 01:01 PM
08/29/07 01:01 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Cool. I agree on why the 6bbl did well. Small engine, decently low peaks. I'm curious tho. It seems that all these are a little softer than I would expect from the parts listed. How mu ch fussing was needed to dial them all in? Which one had the best BSFC at peak tq, and what was that number? I like these tests, but sometimes you just uncover a whole bunch more questions. thanks for making us think!
Re: Best Intake for a Street 383 [Re: DynoDave] #44314
08/29/07 01:10 PM
08/29/07 01:10 PM
Los Angeles, CA
Freiburger Offline OP
Los Angeles, CA
Here are just a few data points. Also, a reminder that this thing had STOCK heads. I think the heads were the restriction, therefore the manifolds did not make drastic changes; except for the really bad ones, the different intakes just wiggled the numbers around by 5-10 hp or shifted them to the low rpm (dual plane) or high rpm (single plane). I'm pretty certain there will be more difference between the intakes once some better heads are on the engine. I find that out at the end of the month.
Street Dominator
3,000: 381, 217
4,000: 449, 342
6,000: 395, 452
Torker
3,000: 395, 225
4,000: 455, 356
6,000: 397, 454
Perf RPM
3,000: 408, 233
4,000: 457, 348
6,000: 392, 448
DP4B
3,000: 419, 239
4,000: 454, 346
6,000: 387, 442
Performer
3,000: 418, 238
4,000: 452, 344
6,000: 382, 436
Six Pack
3,000: 413, 236
4,000: 459, 350
6,000: 391, 447
Re: Best Intake for a Street 383 [Re: Freiburger] #44315
08/29/07 01:19 PM
08/29/07 01:19 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
From the looks of that the DP4B & Torker look pretty darn good considering you can pick one up off ebay for less than $75. Thanks DF
Re: Best Intake for a Street 383 [Re: moper] #44316
08/29/07 01:20 PM
08/29/07 01:20 PM
Los Angeles, CA
Los Angeles, CA
You realize these are average numbers, right? (except for the ones in my most recent post) Peaks with the Six Pack, for example, were 459 lbs-ft at 4,000 and 450 hp at 5,900. I thought that was pretty good for stock heads (you wouldn't get there with stock heads on a similar 383 Chevy).
BSFC at peak torque was .41-.50. Different intakes liked different amounts of fuel. We jetted the Holley on each setup to find optimum, but could not do so on the Six Pack (which was good out of the box, perhaps a little fat) or the Edelbrock dual quads.
Sheez, I might as well just write the entire story here! But the questions help me know what you guys want to see. Thanks.
Re: Best Intake for a Street 383 [Re: Freiburger] #44317
08/29/07 01:33 PM
08/29/07 01:33 PM
C.R. Iowa
supserdave Offline
supserdave  Offline
C.R. Iowa
The real test will be when you get some better heads and a bigger cam. With the weak point being the intake, then the big differences between all of them will come out.
This is still great data, shows you don't have to spend money on aluminum heads and still make good numbers for a street car.
Another side question, is about 450hp the limit for stock heads on a 440 as well, with a similar build?
Re: Best Intake for a Street 383 [Re: supserdave] #44318
08/29/07 01:37 PM
08/29/07 01:37 PM
Los Angeles, CA
Los Angeles, CA
These same heads on Dulcich's 440 made 470 on a differnt dyno. Virtually every 906 head I've ever tested has been limited to 450-470.
The intakes will totally rank differently with a real cam and heads. I think you'll see the RPM get way better then the Performer, the Victor way better than the Torker, etc.
DF
Re: Best Intake for a Street 383 [Re: Freiburger] #44319
08/29/07 01:59 PM
08/29/07 01:59 PM
AndyF Offline
AndyF  Offline
Here is the article I did for Mopar Muscle back in 2005. This was a low deck stroker motor (470 inches) that made 550 at the crank and 475 at the rear tires. The Performer RPM was much better than the Victor 383 for street driving and on the dyno they were very close. The Victor made a little more on the top end but gave up a bunch of torque at the bottom. Since you'll be running headers you might see the Victor make some more power. I was running a MP .528 cam so if your next dyno test uses a bigger cam then the single planes might pull ahead a bit more.
http://www.compcams.com/Community/Articles/Details.asp?ID=2004264609
Re: Best Intake for a Street 383 [Re: AndyF] #44320
08/29/07 02:23 PM
08/29/07 02:23 PM
Los Angeles, CA
Los Angeles, CA
You used an Edelbrock carb both on the dyno and on the street? IMO those tend not to like huge plenum volume because they are signal sensitive. That shows less on the dyno than in part-throttle loading on the street. Holleys are the same, but seem to be more easily band-aided.
I bet that Wilson 2-inch tepered combo spacer really worked on the RPM. I usually find them to add some top end without hurting power anywhere. Then sometimes they don't work at all. Carb spacers are voodoo.
Re: Best Intake for a Street 383 [Re: Freiburger] #44321
08/29/07 03:23 PM
08/29/07 03:23 PM
AndyF Offline
AndyF  Offline
Yep, I used both a 800 AVS and the 800 AFB carb. They both worked okay but we might have been leaving a little on the table. My issue with the Eddy carbs is that the guys at Edelbrock won't provide any aftermarket parts for the carbs so they can't be "tweaked". Without a supply of throttle bodies, venturi clusters, etc. you're limited in what can be done to the carb. If you run out of pump shot for instance you're out of luck.
The Performer RPM liked the carb spacer. The more carb spacer we gave it the better in terms of top end power but the big spacer did cause a bit of a bog. With a Holley DP carb the bog might be covered up but the Edelbrock carb is limited on the pump shot.
Re: Best Intake for a Street 383 [Re: AndyF] #44322
08/29/07 04:39 PM
08/29/07 04:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Well, I didnt realize they were stock heads...lol. I know I read it. I just didnt recall it when it mattered . On the averages, I was thinking the tq average should be fairly close to peak value anyway, given the range of the test values. Meaning they wouldnt have had real peaky results and they'd exibit fairly flat tq curves. Maybe my thinking is off on that too. I'd like to see some back to back stuff if you're bored. A nice one would be the Holley/Edelbrock/Demon/someone's custom shop version carbs on a street type 4.25 stroke BB. Or 2.08 vs 2.14/2.18 valved iron heads with the same level of porting on a small bore (383) wedge.
Re: Best Intake for a Street 383 [Re: moper] #44323
08/29/07 05:21 PM
08/29/07 05:21 PM
AndyF Offline
AndyF  Offline
Well if you're talking to me I'll say that I don't intend to ever do another Mopar article with cast iron heads. The last one I did was the 383 stroker article for Mopar Muscle. The Eddy heads picked up about 50 hp over a set of non-professionally ported 906 heads.
After that dyno test I sold the heads and I also sold all of my core heads. So I don't even have any cast iron heads in my shop anymore and I don't intend to ever buy any or work on any again. Breathing cast iron dust just isn't any fun for me!
http://www.moparmusclemagazine.com/techarticles/mopp_0605_mopar_performance_383_stroker_engine
Re: Best Intake for a Street 383 [Re: AndyF] #44324
08/29/07 06:30 PM
08/29/07 06:30 PM
Los Angeles, CA
Los Angeles, CA
What's amazing is that you saw 500 hp with iron heads. We haven't gotten that from 906s even with bigger engines that have larger cams. Perhaps that pocket porting was better than you thought.
Re: Best Intake for a Street 383 [Re: Freiburger] #44325
08/29/07 09:23 PM
08/29/07 09:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you want to be more amazed , check out the 383 in member fast68plymouth , Dwayne Porter/Porter Racing Heads ... hows 500HP with NON PORTED 906's (ok they are NHRA STOCK LEGAL)it's a 383 , maybe punched out to .060 ??? , the numbers wit hthe stock intake and carb where fairly impressive also .
Re: Best Intake for a Street 383 [Re: JohnRR] #44326
08/29/07 09:57 PM
08/29/07 09:57 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Andy, I was talking more to Dave. I agree using aluminum makes the most sense today. But the vast majority of guys building these things are still using iron. Some with the understanding that they will not end up keeping them on there. And there's some misinformation regarding even their use on some setups due to advances in cylinder head understanding. (like Dwayne's...) I sympathize with you. But reality is there's still thousands more sets of iron being re-used than there are aluminum at this point. And many of the readers of the mags are the guys who will run iron first for budget reasons.
Re: Best Intake for a Street 383 [Re: moper] #44327
08/29/07 10:13 PM
08/29/07 10:13 PM
Los Angeles, CA
Los Angeles, CA
Thing is, by the time you buy some 906s, clean them; mag 'em; mill them; install new guides, valves, and seats; get a valve job; and enlarge the seats, you're halfway to a new set of aluminum heads.
Re: Best Intake for a Street 383 [Re: Freiburger] #44328
08/29/07 11:10 PM
08/29/07 11:10 PM
AndyF Offline
AndyF  Offline
I think I had $1200 in my last set of 906 heads (the ones we used on that 383 stroker motor) after doing all the work. That includes buying new valves, springs, retainers, locks, guides, seals plus doing all the machine work and the bowl hogging. Porting would've been even more.
The Eddy heads are a lot cheaper than a comparable flowing 906 head.
Re: Best Intake for a Street 383 [Re: AndyF] #44329
08/29/07 11:11 PM
08/29/07 11:11 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
Holley Street Dominator
