Re: Best Intake for a Street 383
[Re: DynoDave]
#44313
08/29/07 01:01 PM
08/29/07 01:01 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Cool. I agree on why the 6bbl did well. Small engine, decently low peaks. I'm curious tho. It seems that all these are a little softer than I would expect from the parts listed. How mu ch fussing was needed to dial them all in? Which one had the best BSFC at peak tq, and what was that number? I like these tests, but sometimes you just uncover a whole bunch more questions. thanks for making us think!
[Re: DynoDave]
#44314
08/29/07 01:10 PM
08/29/07 01:10 PM
Posts: 584 Los Angeles, CA
Freiburger
Los Angeles, CA
Here are just a few data points. Also, a reminder that this thing had STOCK heads. I think the heads were the restriction, therefore the manifolds did not make drastic changes; except for the really bad ones, the different intakes just wiggled the numbers around by 5-10 hp or shifted them to the low rpm (dual plane) or high rpm (single plane). I'm pretty certain there will be more difference between the intakes once some better heads are on the engine. I find that out at the end of the month.
Street Dominator 3,000: 381, 217 4,000: 449, 342 6,000: 395, 452
Torker 3,000: 395, 225 4,000: 455, 356 6,000: 397, 454
Perf RPM 3,000: 408, 233 4,000: 457, 348 6,000: 392, 448
DP4B 3,000: 419, 239 4,000: 454, 346 6,000: 387, 442
Performer 3,000: 418, 238 4,000: 452, 344 6,000: 382, 436
Six Pack 3,000: 413, 236 4,000: 459, 350 6,000: 391, 447
[Re: moper]
#44316
08/29/07 01:20 PM
08/29/07 01:20 PM
Freiburger
Los Angeles, CA
You realize these are average numbers, right? (except for the ones in my most recent post) Peaks with the Six Pack, for example, were 459 lbs-ft at 4,000 and 450 hp at 5,900. I thought that was pretty good for stock heads (you wouldn't get there with stock heads on a similar 383 Chevy).
BSFC at peak torque was .41-.50. Different intakes liked different amounts of fuel. We jetted the Holley on each setup to find optimum, but could not do so on the Six Pack (which was good out of the box, perhaps a little fat) or the Edelbrock dual quads.
Sheez, I might as well just write the entire story here! But the questions help me know what you guys want to see. Thanks.
[Re: Freiburger]
#44319
08/29/07 01:59 PM
08/29/07 01:59 PM
Posts: 31,082 Oregon
AndyF
Here is the article I did for Mopar Muscle back in 2005. This was a low deck stroker motor (470 inches) that made 550 at the crank and 475 at the rear tires. The Performer RPM was much better than the Victor 383 for street driving and on the dyno they were very close. The Victor made a little more on the top end but gave up a bunch of torque at the bottom. Since you'll be running headers you might see the Victor make some more power. I was running a MP .528 cam so if your next dyno test uses a bigger cam then the single planes might pull ahead a bit more. http://www.compcams.com/Community/Articles/Details.asp?ID=2004264609
[Re: AndyF]
#44322
08/29/07 04:39 PM
08/29/07 04:39 PM
moper
Columbia, CT
Well, I didnt realize they were stock heads...lol. I know I read it. I just didnt recall it when it mattered . On the averages, I was thinking the tq average should be fairly close to peak value anyway, given the range of the test values. Meaning they wouldnt have had real peaky results and they'd exibit fairly flat tq curves. Maybe my thinking is off on that too. I'd like to see some back to back stuff if you're bored. A nice one would be the Holley/Edelbrock/Demon/someone's custom shop version carbs on a street type 4.25 stroke BB. Or 2.08 vs 2.14/2.18 valved iron heads with the same level of porting on a small bore (383) wedge.
[Re: moper]
#44323
08/29/07 05:21 PM
08/29/07 05:21 PM
AndyF
Well if you're talking to me I'll say that I don't intend to ever do another Mopar article with cast iron heads. The last one I did was the 383 stroker article for Mopar Muscle. The Eddy heads picked up about 50 hp over a set of non-professionally ported 906 heads. After that dyno test I sold the heads and I also sold all of my core heads. So I don't even have any cast iron heads in my shop anymore and I don't intend to ever buy any or work on any again. Breathing cast iron dust just isn't any fun for me! http://www.moparmusclemagazine.com/techarticles/mopp_0605_mopar_performance_383_stroker_engine
[Re: Freiburger]
#44325
08/29/07 09:23 PM
08/29/07 09:23 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
What's amazing is that you saw 500 hp with iron heads. We haven't gotten that from 906s even with bigger engines that have larger cams. Perhaps that pocket porting was better than you thought.
you want to be more amazed , check out the 383 in member fast68plymouth , Dwayne Porter/Porter Racing Heads ... hows 500HP with NON PORTED 906's (ok they are NHRA STOCK LEGAL)it's a 383 , maybe punched out to .060 ??? , the numbers wit hthe stock intake and carb where fairly impressive also .
[Re: JohnRR]
#44326
08/29/07 09:57 PM
08/29/07 09:57 PM
moper
Columbia, CT
Andy, I was talking more to Dave. I agree using aluminum makes the most sense today. But the vast majority of guys building these things are still using iron. Some with the understanding that they will not end up keeping them on there. And there's some misinformation regarding even their use on some setups due to advances in cylinder head understanding. (like Dwayne's...) I sympathize with you. But reality is there's still thousands more sets of iron being re-used than there are aluminum at this point. And many of the readers of the mags are the guys who will run iron first for budget reasons.
