Re: How many Volts
[Re: emarine01]
#443053
08/19/09 04:34 PM
08/19/09 04:34 PM
Posts: 526 NC
barracuda man
NC
Yes, My MSD doesn't like anything below 12.3 you need more stored amps or a charging system, the higher the volts the less the amp draw, your voltage is way too low
Guess its time for a new battery.
Re: How many Volts
[Re: barracuda man]
#443054
08/19/09 04:38 PM
08/19/09 04:38 PM
Posts: 3,695 nc
emarine01
nc
Or 2
Re: How many Volts
[Re: emarine01]
#443055
08/19/09 04:47 PM
08/19/09 04:47 PM
Posts: 526 NC
barracuda man
NC
Or 2
Thats right.the car runs 7.04 ets consistent.but here lately it runs 7.15 first two time runs.then bamb 7.04 cool the car down.bamb back to 7.15 seems the longer i charge the battery the faster it runs.
Re: How many Volts
[Re: barracuda man]
#443057
08/19/09 05:31 PM
08/19/09 05:31 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Found a slick little voltage stepup box from SpeedwayMotors.com #935-64000. Puts 17.5-17.7 volts into the MSD with batt voltage as low as 10.5V. Haven't made a pass yet but guys using it swear by it.
The little old lady from Pasadena is back!
Re: How many Volts
[Re: Barnstorm]
#443058
08/19/09 06:33 PM
08/19/09 06:33 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
Here is some real world data, the bottom graph is battery voltage, this is a car without an alternator and two batteries, return style fuel regulator, mallory 250 fuel pump, MSD 7al, Mega 85 Delay box, RPM datalogger running, ACD controlled CO2 shifter, Moroso electric water pump drive, dash and tail lights(LED), and a Shogun LED dial board on. I charge every round. FYI, just data. Open attachement and view full screen to best view.
Re: How many Volts
[Re: Thumperdart]
#443059
08/19/09 08:24 PM
08/19/09 08:24 PM
Posts: 526 NC
barracuda man
NC
Forget the battery............install an alternator and avoid all bs affiliated w/racing w/out one.
last time i tryed running the alternater i had way to many volts and fried two rpm tacks.whats the best way to hook it up.do i need the alternator regulator or can i run without.
Re: How many Volts
[Re: barracuda man]
#443060
08/19/09 10:01 PM
08/19/09 10:01 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
You can run a later model alternator with an internal regulator, I just put a Powermaster on mine.
Re: How many Volts
[Re: mike67net]
#443061
08/19/09 10:26 PM
08/19/09 10:26 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
I run 2 batteries and GM alt never thought i would need a jump till 3rd round sat click click .Lost the rd .001 - red ouch checked volts at batteries 11.5 started it and 12.5 tach was jumping in high gear. NOW i know why had alt checked 15 volts put on car 14 at batts now What gives???4years thought about putting a trickle charge and load test them . msd6al 2 fans transbrake 2 step dash lites ,tail lites put a alt on if your bracket racing DON
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: How many Volts
[Re: mike67net]
#443062
08/19/09 10:32 PM
08/19/09 10:32 PM
Posts: 526 NC
barracuda man
NC
What part# on the powermaster.I'm doing a search man them things are high dollar.
Re: How many Volts
[Re: Barnstorm]
#443065
08/19/09 10:41 PM
08/19/09 10:41 PM
Posts: 989 Rather be in Fallon, Nevada
RussW
super gas
super gas
Do you think it would be any benefit to a 6AL ?
Re: How many Volts
[Re: barracuda man]
#443066
08/19/09 10:51 PM
08/19/09 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a 85 amp Denso alt with a external regulator (I use the high out put Mopar regulator) and I use just a single battery.... I cant remember how many years its been since I put a charger on it. Trans brake, water pump, fan, 7al, 2 fuel pumps and a tail light plus I'm putting a small fan in the car to circulate some air inside
Re: How many Volts
[Re: barracuda man]
#443067
08/19/09 10:56 PM
08/19/09 10:56 PM
Posts: 5,445 So Cal
Sinitro
So Cal
A couple of thoughts.. The MSD boxes need voltage to run. Regarding the alternator, a trick we have run on some of our cars is to switch off the alternator's Field lead.. EZ to install a simple toggle switch in series for the Field wire lead, turn it OFF when rippin down the strip. Turn it ON to keep the battery charged. Many people don't realize how much drag the alternator pulls while charging.. Just my $0.015...
Re: How many Volts
[Re: Sinitro]
#443068
08/19/09 11:04 PM
08/19/09 11:04 PM
MR_P_BODY
Just my $0.015...
I use to do that... made 0 difference
