How many Volts #443049
08/19/09 04:21 PM
08/19/09 04:21 PM
NC
barracuda man Offline OP
NC
I run a 12volt battery with no alt.Charge after every round.I have the msd 6al/elec fan/elec water pump/elec fuel pump.The volts read 10 1/2 to 11 volts with car running.Will this cause the car to run inconsistent.
Re: How many Volts [Re: barracuda man] #443050
08/19/09 04:27 PM
08/19/09 04:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My understanding is that most ignitions especially MSD need at least 12.5 volts to function properly not to mention the load w/the other elec. components you mentioned. It makes no sense in my warped mind NOT to run an alternator.
Re: How many Volts [Re: barracuda man] #443051
08/19/09 04:29 PM
08/19/09 04:29 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Yes, My MSD doesn't like anything below 12.3 you need more stored amps or a charging system, the higher the volts the less the amp draw, your voltage is way too low
Re: How many Volts [Re: Thumperdart] #443052
08/19/09 04:32 PM
08/19/09 04:32 PM
NC
NC
I used to run one but it kepted burning up my tacks.So i took it off.I need to have the car rewired but moneys kind of tight.
Re: How many Volts [Re: emarine01] #443053
08/19/09 04:34 PM
08/19/09 04:34 PM
NC
NC
Guess its time for a new battery.
Re: How many Volts [Re: barracuda man] #443054
08/19/09 04:38 PM
08/19/09 04:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Or 2
Re: How many Volts [Re: emarine01] #443055
08/19/09 04:47 PM
08/19/09 04:47 PM
NC
NC
Or 2
Thats right.the car runs 7.04 ets consistent.but here lately it runs 7.15 first two time runs.then bamb 7.04 cool the car down.bamb back to 7.15 seems the longer i charge the battery the faster it runs.
Re: How many Volts [Re: barracuda man] #443056
08/19/09 05:25 PM
08/19/09 05:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Forget the battery............install an alternator and avoid all bs affiliated w/racing w/out one.
Re: How many Volts [Re: barracuda man] #443057
08/19/09 05:31 PM
08/19/09 05:31 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Found a slick little voltage stepup box from SpeedwayMotors.com #935-64000. Puts 17.5-17.7 volts into the MSD with batt voltage as low as 10.5V. Haven't made a pass yet but guys using it swear by it.
The little old lady from Pasadena is back!
Re: How many Volts [Re: Barnstorm] #443058
08/19/09 06:33 PM
08/19/09 06:33 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Here is some real world data, the bottom graph is battery voltage, this is a car without an alternator and two batteries, return style fuel regulator, mallory 250 fuel pump, MSD 7al, Mega 85 Delay box, RPM datalogger running, ACD controlled CO2 shifter, Moroso electric water pump drive, dash and tail lights(LED), and a Shogun LED dial board on. I charge every round. FYI, just data. Open attachement and view full screen to best view.
Re: How many Volts [Re: Thumperdart] #443059
08/19/09 08:24 PM
08/19/09 08:24 PM
NC
NC
last time i tryed running the alternater i had way to many volts and fried two rpm tacks.whats the best way to hook it up.do i need the alternator regulator or can i run without.
Re: How many Volts [Re: barracuda man] #443060
08/19/09 10:01 PM
08/19/09 10:01 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
You can run a later model alternator with an internal regulator, I just put a Powermaster on mine.
Re: How many Volts [Re: mike67net] #443061
08/19/09 10:26 PM
08/19/09 10:26 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
I run 2 batteries andGM alt never thought i would need a jump till 3rd round sat click click .Lost the rd .001 - red ouch
checked volts at batteries 11.5 started it and 12.5 tach was jumping in high gear.
NOW i know why
had alt checked 15 volts put on car 14 at batts now
What gives???4years
thought about putting a trickle charge and load test them .
msd6al
2 fans
transbrake
2 step
dash lites ,tail lites
put a alt on if your bracket racing
DON
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: How many Volts [Re: mike67net] #443062
08/19/09 10:32 PM
08/19/09 10:32 PM
NC
NC
What part# on the powermaster.I'm doing a search man them things are high dollar.
Re: How many Volts [Re: 10 o to go] #443063
08/19/09 10:33 PM
08/19/09 10:33 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I have ran a altenator for years. I still charge the battery while cooling down. Autozone 7127M Duralast. Has a lifetime warranty. I am on #3 in over ten years but they are free.
Why does divorce cost so much? Because it is worth it!!!!!
Re: How many Volts [Re: barracuda man] #443064
08/19/09 10:34 PM
08/19/09 10:34 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I run 2 batteries and a 1 wire Delcotron (80's GM)Alternator, never have to charge. Voltage is steady @ about 13.5. I have tried it both ways and when you go a lot of rounds and they get quicker, anything after the quarters, you don't have time to charge, one time not starting going into a final and you will be convinced.
Re: How many Volts [Re: Barnstorm] #443065
08/19/09 10:41 PM
08/19/09 10:41 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Do you think it would be any benefit to a 6AL ?
Re: How many Volts [Re: barracuda man] #443066
08/19/09 10:51 PM
08/19/09 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a 85 amp Denso alt with a external regulator
(I use the high out put Mopar regulator) and I use
just a single battery.... I cant remember how many
years its been since I put a charger on it.
Trans brake, water pump, fan, 7al, 2 fuel pumps and
a tail light plus I'm putting a small fan in the car
to circulate some air inside
Re: How many Volts [Re: barracuda man] #443067
08/19/09 10:56 PM
08/19/09 10:56 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
A couple of thoughts..
The MSD boxes need voltage to run. Regarding the alternator, a trick we have run on some of our cars is to switch off the alternator's Field lead..
EZ to install a simple toggle switch in series for the Field wire lead, turn it OFF when rippin down the strip. Turn it ON to keep the battery charged. Many people don't realize how much drag the alternator pulls while charging..
Just my $0.015...
Re: How many Volts [Re: Sinitro] #443068
08/19/09 11:04 PM
08/19/09 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just my $0.015...
I use to do that... made 0 difference
