340 Crank Shaft #442627
08/19/09 06:20 AM
08/19/09 06:20 AM
Michigan, USA
sixpackman Offline OP
Michigan, USA
I'm looking to build a TA motor for my AAR. In the car currently is a 1973 short block with the upper end all TA.
Is there a problem using the 73 crank shaft? Does the TA motors have a special crank? Or do I have to find a 1970 crank?
Thanks MoParts
Re: 340 Crank Shaft [Re: sixpackman] #442628
08/19/09 06:38 AM
08/19/09 06:38 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use your shaft. The T/A was built while the shafts were still forged but so what. They also had special designed heads with offset pushrod passages.
Re: 340 Crank Shaft [Re: MoparforLife] #442629
08/19/09 07:28 AM
08/19/09 07:28 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
it's easy to spot a weighted balancer and #'s on the block.
Re: 340 Crank Shaft [Re: stinger] #442630
08/19/09 08:32 AM
08/19/09 08:32 AM
montreal, quebec, canada
jimmy71demon Offline
this may sound like a stupid question from a newbie, but whats a TA engine?
Im goin fast Mom!
Re: 340 Crank Shaft [Re: stinger] #442631
08/19/09 08:55 AM
08/19/09 08:55 AM
Upper Midwest
Upper Midwest
If you have a complete short block with crankshftfrom a 73 it should have the correct 'for cast crankshaft 340 only' damper on it. you will also need a torque converter, or a cast 340 flex plate (not both), or flywheel that is weighted for the cast shaft.
Re: 340 Crank Shaft [Re: jimmy71demon] #442632
08/19/09 11:52 AM
08/19/09 11:52 AM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
340 six pack engine from either a AAR cuda or a challenger T/A.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 340 Crank Shaft [Re: 73cuda340] #442633
08/19/09 12:17 PM
08/19/09 12:17 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Have the engine internally balanced and use the std 340 balancer. Poof.. instant "correct" 340.
Re: 340 Crank Shaft [Re: jimmy71demon] #442634
08/19/09 12:27 PM
08/19/09 12:27 PM
there are no stupid questions only(on occaision) rude answers. TA is trans am I believe(no relation to the other trans am)
Re: 340 Crank Shaft [Re: RapidRobert] #442635
08/19/09 12:45 PM
08/19/09 12:45 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I know where you can score a 340 forged crank ready to go CHEAP!
Re: 340 Crank Shaft [Re: stinger] #442636
08/19/09 01:18 PM
08/19/09 01:18 PM
and all TA's are six packs?
u c im only 25, i wasnt around when all these cars were in their prime like lots of u guys were. lol but im learning lots about them on here! thanks guys!!!
party on wayne
Im goin fast Mom!
Re: 340 Crank Shaft [Re: jimmy71demon] #442637
08/19/09 02:22 PM
08/19/09 02:22 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..1970 T/A challengers and AAR cudas were 340 six pac only...
and the 340 6pacs were in only aar and ta from the factory...
Tony
70 AARCuda Vitamin C
Re: 340 Crank Shaft [Re: 70AARcuda] #442638
08/19/09 03:09 PM
08/19/09 03:09 PM
Upper Midwest
Upper Midwest
AAR Cuda
T/A Challenger
note exhaust exit - Only on these models.
