Re: iron versus aluminum
[Re: mayhem148]
#442576
08/19/09 07:29 AM
08/19/09 07:29 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Ally blocks KB at least have superior strength as well as optimized oiling compared to iron . They are easier to repair not to mention the weight savings.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: mayhem148]
#442578
08/19/09 08:57 AM
08/19/09 08:57 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Aluminum is light, easily repairable if windowed, and you can resleeve if you hurt a cylinder. The ONLY downside is the cost.
Cast iron is heavy, it's a boat anchor if you window it, sure you CAN sleeve it, but not like an aluminum block.
In my opinion, if you have the money...there is only one way to go. That's why I have a KB block in my cuda. CHIP
[Re: an8sec70cuda]
#442579
08/19/09 09:35 AM
08/19/09 09:35 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I agree. There may be some here chime in about thermo/power loss. That's all BS. There may be some cylinder movement that can slightly affect ring seal but it's minimal compared to the advantages aluminum has over iron.
[Re: an8sec70cuda]
#442580
08/19/09 02:51 PM
08/19/09 02:51 PM
Posts: 627 IN
BIG BEAR
IN
Do you think that alumium is as strong as iron?
[Re: BIG BEAR]
#442581
08/19/09 02:57 PM
08/19/09 02:57 PM
Posts: 761 KY
juicedcuda
KY
And is there any problems just cruising an aluminum block on the street?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
[Re: BobR]
#442582
08/19/09 04:05 PM
08/19/09 04:05 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
If your running a N/A motor with NO power adders then the aluminum may be the way to go, maybe not if you can't afford to lose a certian amount percentage wise of the total HP attainable. MY example is Pro Stock, they can run any block material they want, once they lobby NHRA for it, and all of them are using Compact Graphite Iron blocks not aluminum
[Re: Cab_Burge]
#442583
08/19/09 04:15 PM
08/19/09 04:15 PM
Posts: 705 Michigan
Hemiroid
If you're running a n/a motor that's not heads up, then the aluminum is probably the way to go. Even in a heads up situation, taking that weight off of the nose of the car and the overall weight savings coupled with repairability probably make aluminum the best choice even with the slight loss of hp in the ring seal. The new world iron blocks, without cnc lightening weigh like 200 lbs more than a alum block!
[Re: juicedcuda]
#442585
08/19/09 05:01 PM
08/19/09 05:01 PM
an8sec70cuda
No problems cruising an aluminum block on the street. Most of the cars on the road today have aluminum blocks. Mine's been on the street and strip for 3+ years w/ no problems. All the pro mods I've seen run aluminum blocks. They are billet, but still aluminum. My good friend has a big NASTY BB Chevy ex pro mod motor that's a cast aluminum block. Another good friend has a 540" Jim Oddy blower motor that made some ridiculous power... aluminum block. The CGI blocks may be the best for making power, but the majority of the time you'd rather have the weight savings of aluminum. Regular cast iron really shouldn't be an option for you unless cost is a factor. CHIP
[Re: juicedcuda]
#442587
08/19/09 10:29 PM
08/19/09 10:29 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
and just because a handfull of people did it does not mean it is reliable.
[Re: blownzoom440]
#442588
08/20/09 08:11 AM
08/20/09 08:11 AM
an8sec70cuda
Why isn't it reliable? Please, do tell? CHIP
[Re: an8sec70cuda]
#442589
08/20/09 09:07 AM
08/20/09 09:07 AM
blownzoom440
ELYRIA,OH
my point was about the pressed in sleeves possably leaking if nothing else over time.
[Re: blownzoom440]
#442590
08/20/09 09:14 AM
08/20/09 09:14 AM
BobR
Left Coast
Aluminum blocks are every bit as reliable as iron. All the GM LS1, LS2, LS6 and LS7 blocks are aluminum. Many of the import high perf blocks are aluminum as well. I have an aluminum block on my Cobra replica-4 years and running with zero problems. The NHRA pro stock guys use compacted graphite blocks but the IHRA guys all use aluminum for their mountain motors.
[Re: BobR]
#442591
08/20/09 09:27 AM
08/20/09 09:27 AM
blownzoom440
ELYRIA,OH
you did not name 1 mopar block[aluminum aftermarket].i am not trying to argue but learn from this post.
[Re: blownzoom440]
#442592
08/20/09 09:37 AM
08/20/09 09:37 AM
BobR
Left Coast
Holds true for these as well. A couple have vouched for their aluminum block's integrity. My post was just vouching for the integrity of aluminum in general.
http://www.jimsautoparts.com/mopar_performance_blocks.htm
[Re: blownzoom440]
#442594
08/20/09 10:02 AM
08/20/09 10:02 AM
an8sec70cuda
The old aluminum blocks had wet sleeves with O-rings that sometimes leaked. Not anymore, they now use dry sleeves and have done so for many years. So no worries about leaking water. CHIP
