New CSR Water Pump , no flow! #442499
08/18/09 10:13 PM
08/18/09 10:13 PM
Ohio
Lil Wedge Offline OP
Ohio
I picked up a new small block CSR water pump, new still in box, but I bought it from a friend, who bought it from a friend, so no warranty , and installed it and went through quite a bit of trouble relocating alternator, and after all this work it wont pump, motor runs, won't pump. Rechecked wiring, even hooked it up backwards, won't pump either way. Really sucks ?
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442500
08/18/09 10:15 PM
08/18/09 10:15 PM
Renton Washington
Triple Threat Offline
Renton Washington
Air bubble ?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442501
08/18/09 10:17 PM
08/18/09 10:17 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
When I installed the electric pump on the cuda the pump would over power the thermostat spring and keep it closed. I had to remove the guts out of the thermostat and all was well....pumped like crazy then...Phill
Re: New CSR Water Pump , no flow! [Re: 9 Sec Phill] #442502
08/18/09 10:34 PM
08/18/09 10:34 PM
Ohio
Ohio
No thermostat , just a restrictor, with the stock pump and Moroso belt drive, never had a problem, flow was great,cross flow aluminum radiator and you could see lots of movement. Acts like this one has an impeller problem. I got disgusted and walked away, I guess I will tear it apart tomorrow and find out.
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442503
08/18/09 10:39 PM
08/18/09 10:39 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It's probably air locked.
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442504
08/18/09 10:39 PM
08/18/09 10:39 PM
ky
68roadrunner Offline
ky
got one for my big block. it flowed all right, flowed right in to the floor.bought a meziere and sent csr back, stupid thing
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442505
08/18/09 10:40 PM
08/18/09 10:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I had to pressurize my Meziere with a little air in the radiator to get it to start flowing. Then I had to get all the air out of the system,
Re: New CSR Water Pump , no flow! [Re: 68roadrunner] #442506
08/18/09 10:45 PM
08/18/09 10:45 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I had the same problem....it's cavitating in the timing cover.
You'll have to take the plate off that covers the timing cover and get a piece welded in, and prevents the water to circulate in the cover, that forces the water through the heads.
I think the piece that got welded i was about 1/8" x 1".
Check it and see, that was the reply I got to the very same question.
good luck
Re: New CSR Water Pump , no flow! [Re: markz528] #442507
08/18/09 10:48 PM
08/18/09 10:48 PM
south louisiana
lowell66dart Offline
south louisiana
Try putting the cap on the radiator and then squeezing the radiator hoses to get the air pocket moving. If that doesn't work your going to have to loosen the allen head bolts closest to the pump motor with the pump running. Your trying to get air out. Sometimes I have to even take a bolt out of either side and roll the pump a little to get the air out.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: New CSR Water Pump , no flow! [Re: lowell66dart] #442508
08/18/09 11:02 PM
08/18/09 11:02 PM
Ohio
Ohio
The other problem with this,I am using a motor plate, While it may not matter, it is another 1/4" or so,But I used the stock water pump this way and had no problem, in fact wish I had never seen this new one,lol Stock one worked fine,but the motor went bad, new Moroso kit was $79.00, this was $100.00. Actually a 69 Mustang Blower motor looks the same as Moroso water pump motor and NAPA has for $23.00.
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442509
08/18/09 11:05 PM
08/18/09 11:05 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
If you look close in this picture to the right of the pump mototr you will see where i drilled a bleed hole. everytime i fill it fromm scratch it needs to be bled after that its fine.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442510
08/19/09 12:21 AM
08/19/09 12:21 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Those things are terrible about air locks. I cured mine with the attached mod. I can release all the air and it has never failed.
Re: New CSR Water Pump , no flow! [Re: Blucuda413] #442511
08/19/09 09:45 PM
08/19/09 09:45 PM
Ohio
Ohio
Want to thank everyone, Burped the air and it works just fine!Only thing I noticed is I used to start it let it build to about 130 degrees and turn on the water pump and temp gauge would drop back down to nothing and gradually build back up,and go all the way up to about 190, this one didn't do that,just stayed at 130 and then built up to 150-160 and ran it quite a while. Would have had to shut it off with old pump. Thanks again, I was pretty disgusted, Just spent a month,pulling trans about 5 times to fix a leak which turned out to be converter snout (which was fairly new)and I kept going through the pump,and I pulled the engine for a hairline crack in the Milodon oil pan and replaced. Just a long 5 weeks or so....
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442512
08/19/09 10:02 PM
08/19/09 10:02 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Kool, glad you got it figured out..
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442513
08/19/09 10:11 PM
08/19/09 10:11 PM
S/ST 3040 Offline
S/ST 3040  Offline
Damn it! I was hoping I could find the motor to
my old Moroso belt driven one to trade you.
Glad you got it going.
Re: New CSR Water Pump , no flow! [Re: Lil Wedge] #442514
08/19/09 10:33 PM
08/19/09 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the same problem every year after I drain
the anti freeze... it gets a air pocket, I'll fill
it then warm the engine up(pump turned off) and when
it gets warm I shut down the engine then turn the
pump on and off a few times then it'll finally pump,
then I can top off the cooling and all is well.
I also put a clear plastic tube in the upper radiator
hose just to make sure its pumping. I only have the
problem if the cooling system has been drained
Re: New CSR Water Pump , no flow! [Re: MR_P_BODY] #442515
08/19/09 11:10 PM
08/19/09 11:10 PM
south louisiana
south louisiana
Another thing that I always do is start the pump before I crank the engine. That way if you have any seepage on the head gaskets when cold you have less of a chance of putting air into the system.
