NEW FUEL CELL..... #442409
08/18/09 08:49 PM
08/18/09 08:49 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Well I got the pump, filter , and the rear of the fuel cell mounted tonight.. So now all I have to do is hook up the lines and run the return and make front brackets for it then I'm done.. But thank god my wife is small. I could have never goten my hand in the cell to put the return fitting in, until she she hey honey why not take the ring off... So anyhow here it is, what do ya think..
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442410
08/18/09 09:07 PM
08/18/09 09:07 PM
ky
68roadrunner Offline
ky
hey looks good, where is you relay mounted? finish it up pump some fuel, smell some smoke.
Re: NEW FUEL CELL..... [Re: 68roadrunner] #442411
08/18/09 09:10 PM
08/18/09 09:10 PM
Deerfield, Ohio
Deerfield, Ohio
Its mounted just behind the cell. I haven't moved it yet.. Thats just where it was with the old pump.. Thanks..
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442412
08/18/09 09:17 PM
08/18/09 09:17 PM
ky
ky
Re: NEW FUEL CELL..... [Re: 68roadrunner] #442413
08/18/09 11:37 PM
08/18/09 11:37 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
It looks like the back is kind of free floating, even if theres straps under neath. Tech guy might have a problem with that.
Otherwise,
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442414
08/18/09 11:56 PM
08/18/09 11:56 PM
Which pump and filter did you end up with?
Re: NEW FUEL CELL..... [Re: Cab_Burge] #442415
08/19/09 07:24 AM
08/19/09 07:24 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Looks good ! Lines to the pump look a little small though. All depends on the HP level though . #12 to the pump #10 to the regs.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: NEW FUEL CELL..... [Re: Cab_Burge] #442416
08/19/09 09:06 AM
08/19/09 09:06 AM
Deerfield, Ohio
Deerfield, Ohio
Ended up with the Mallory 250 pump and filter I think it was the 500.. The lines are -10 to -8 from the pump.. Moneys tight and the -8 lines where there so I used them.. and then -10 return.. Im going to up grade later on.. The back of the tank isn't supported yet.. I got to make brackets for it, try to get that done tonight..
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442417
08/19/09 09:34 AM
08/19/09 09:34 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
dont forget the ground strap from the fuel cell fill hole to the frame.to get your hand inside the cell sometimes you need to take off the fill cap ring[not sure of itom name]then reinstall it.the foam can be removed easier this way also.
Re: NEW FUEL CELL..... [Re: blownzoom440] #442418
08/19/09 12:54 PM
08/19/09 12:54 PM
Deerfield, Ohio
Deerfield, Ohio
I need some ideas on how to mount the back of the cell, what type of brackest did you use and so forth.. Thanks..
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442419
08/19/09 01:10 PM
08/19/09 01:10 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
Mine is mounted in the tire well on aluminum
square blocks of metal bolted through the floor
pan with washers/nuts.
But if you are going to keep it up high like
showen in your picture then you will need to
built some kind of a frame to support the
weight of the cell/fuel.
Phil Saran Parker, Colorado
Re: NEW FUEL CELL..... [Re: Phil Saran] #442420
08/19/09 01:14 PM
08/19/09 01:14 PM
Deerfield, Ohio
Deerfield, Ohio
Yeah, I'd like to keep it up there, it just makes it easier for the lines plus I mounted the pump and filter on the chute mount in the well. So I'm not sure if just like some L brackets would work or I'd have to build a whole new frame for it. Think cheap though.. I'm broke..LOL
Re: NEW FUEL CELL..... [Re: Phil Saran] #442421
08/19/09 01:16 PM
08/19/09 01:16 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Mine has 2 pieces of 2" strap (1/8" thick) welded across the tire well from front to back, nice and simple and looks clean...
Re: NEW FUEL CELL..... [Re: BB70DUSTER] #442422
08/19/09 01:24 PM
08/19/09 01:24 PM
Deerfield, Ohio
Deerfield, Ohio
Do you have any photos that you could post. Thanks..
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442423
08/19/09 04:09 PM
08/19/09 04:09 PM
Some two inch aluminum or steel angle will work, bolted into and across the floor, bolt the fuel cell retaining straps onto the angle
Re: NEW FUEL CELL..... [Re: Cab_Burge] #442424
08/19/09 05:36 PM
08/19/09 05:36 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
If you`re running a glass deck lid you could do as I had done and mount your rear bracket to where the striker was located for the trunk latch is . Since you aren`t using it now. Have a close look at the pic. of mine.
Re: NEW FUEL CELL..... [Re: 70dusterjohn] #442425
08/20/09 12:09 AM
08/20/09 12:09 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
When any discussion on fuel cells takes place, I like to know if car is ever driven on the street, and if so, with any passengers? Those answers I think are important as to how problems are solved. And for asking others.
Re: NEW FUEL CELL..... [Re: jcc] #442426
08/20/09 01:07 AM
08/20/09 01:07 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
heres how i did mine
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: NEW FUEL CELL..... [Re: jcc] #442427
08/20/09 04:13 PM
08/20/09 04:13 PM
Deerfield, Ohio
Deerfield, Ohio
Yes its street driven, only front seat passengers..
