Re: NEW FUEL CELL.....
[Re: 68roadrunner]
#442411
08/18/09 09:10 PM
08/18/09 09:10 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
hey looks good, where is you relay mounted? finish it up pump some fuel, smell some smoke.
Its mounted just behind the cell. I haven't moved it yet.. Thats just where it was with the old pump.. Thanks..
[Re: 70dusterjohn]
#442414
08/18/09 11:56 PM
08/18/09 11:56 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Which pump and filter did you end up with?
[Re: Cab_Burge]
#442415
08/19/09 07:24 AM
08/19/09 07:24 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Looks good ! Lines to the pump look a little small though. All depends on the HP level though . #12 to the pump #10 to the regs.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Cab_Burge]
#442416
08/19/09 09:06 AM
08/19/09 09:06 AM
70dusterjohn
Deerfield, Ohio
Ended up with the Mallory 250 pump and filter I think it was the 500.. The lines are -10 to -8 from the pump.. Moneys tight and the -8 lines where there so I used them.. and then -10 return.. Im going to up grade later on.. The back of the tank isn't supported yet.. I got to make brackets for it, try to get that done tonight..
[Re: 70dusterjohn]
#442419
08/19/09 01:10 PM
08/19/09 01:10 PM
Posts: 396 California, USA
Phil Saran
California, USA
Mine is mounted in the tire well on aluminum square blocks of metal bolted through the floor pan with washers/nuts.
But if you are going to keep it up high like showen in your picture then you will need to built some kind of a frame to support the weight of the cell/fuel.
Phil Saran
Parker, Colorado
[Re: Cab_Burge]
#442424
08/19/09 05:36 PM
08/19/09 05:36 PM
chryco
Winnipeg ,Mb. CA.
If you`re running a glass deck lid you could do as I had done and mount your rear bracket to where the striker was located for the trunk latch is . Since you aren`t using it now. Have a close look at the pic. of mine.
[Re: jcc]
#442427
08/20/09 04:13 PM
08/20/09 04:13 PM
70dusterjohn
Deerfield, Ohio
When any discussion on fuel cells takes place, I like to know if car is ever driven on the street, and if so, with any passengers? Those answers I think are important as to how problems are solved. And for asking others.
Yes its street driven, only front seat passengers..
