Re: Who makes the A12 hood pin bracket for the back
[Re: 79machocharger]
#44174
08/24/07 03:26 PM
08/24/07 03:26 PM
Posts: 6,301 colorado
a12superbee
colorado
You can get them from y1 but I can't recall the differences between them and the originals if you're looking for perfect.
I can't afford this.
mark
[Re: dstryr]
#44176
08/24/07 05:21 PM
08/24/07 05:21 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Jack's has them, also...
B-body parts
The brackets from Jack's look like they use a little heavier gauge metal than the YR-1 brackets I have a set of YR-1 and a set of original brackets, the YR-1's are cheaply made IMO and
I'd try the ones from Jack's if I was looking for another set.
MikeR
Here are a set of originals...complete....(Hey MikeE, check out the "Bahama Yellow Primer" on them )
[Re: Q5_Ed]
#44179
08/25/07 02:10 PM
08/25/07 02:10 PM
Posts: 21,453 It's a dry heat
gtx6970
It's a dry heat
I think this has been brought up before and found Hoffmans brckts are the best sets avail. If someone would like to measure a known set of originals, I will do the same on the HWC supplied reproductions ps- HWC no longer sells direct
[Re: gtx6970]
#44180
08/26/07 03:24 PM
08/26/07 03:24 PM
A12
N.E. OHIO, USA
Bill, I've packed these away since the photos but I think they are 3/16" thick. I'll have to dig them out to be sure. Here's the measurements I took a while back.....it was tough to hold the tape measure and click off the photos
[Re: A12]
#44181
08/26/07 03:29 PM
08/26/07 03:29 PM
A12
N.E. OHIO, USA
[Re: A12]
#44182
08/26/07 03:30 PM
08/26/07 03:30 PM
A12
N.E. OHIO, USA
#44185
08/27/07 01:16 PM
08/27/07 01:16 PM
A12
N.E. OHIO, USA
Thanks guys. Also I found these on ebay http://cgi.ebay.com/ebaymotors/Mopar-69-...sspagenameZWDVW, are they any good? There going on a driver so they dont have to be perfect.
I questioned the correctness of the first "kit" that they advertized but this current set looks very correct (IMO). My opinion is more from the hood pin shape than anything. The lanyards look fairly correct and they provide rivets instead of screws and correct looking washers.
MikeR
[Re: A12]
#44186
08/28/07 04:31 PM
08/28/07 04:31 PM
Posts: 4,150 VA
RapidRunner
VA
Wonder if that's the same kit Frank Sells????
MikeE (Bahama Yellow Primer Man!)
Who knows? The Shadow Knows! But he ain't on this fraking forum!
"This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!"
[Re: RapidRunner]
#44187
08/28/07 04:39 PM
08/28/07 04:39 PM
Posts: 3,691 The Last Frontier
Alaska_A12
The Last Frontier
Good question!! It is $140 I think on Frank's website. Could they be getting it from the same source?
Anybody get one of these Ebay kits yet?
I want to get the right set-up to put on this winter when I "Organisol" the hood.
[Re: megaparts]
#44190
08/29/07 12:59 PM
08/29/07 12:59 PM
Alaska_A12
The Last Frontier
The Kit on eBay is probably the same one we sell. They are made by Dale's Cuda Shop.
Any idea if they are any different than Roger & Frank's?
[Re: Alaska_A12]
#44191
08/29/07 07:07 PM
08/29/07 07:07 PM
Posts: 467 Coon Valley, WI
megaparts
Coon Valley, WI
I don't know. I have never seen Roger and Frank's Kits
[Re: megaparts]
#44192
09/01/07 10:09 PM
09/01/07 10:09 PM
yes they are the same kit as frank and roger and mega parts and r/t specialties and others
