need help with P/N for 69 440 Cast Iron Bell Housing #441744
08/18/09 12:40 AM
08/18/09 12:40 AM
Arizona, usa
mcoderoadrunner Offline OP
Arizona, usa
I need helpl with the cast iron bell housing part number for a 1969.5 A12 4 speed car.
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: mcoderoadrunner] #441745
08/18/09 08:03 AM
08/18/09 08:03 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I was told that cars had alluminium and trucks had iron?.
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: mcoderoadrunner] #441746
08/18/09 11:10 AM
08/18/09 11:10 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
They do exist. I had one, was for 143 tooth flywheel. Traded it off and can't find the part#. It's online, just do a search.
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: moparsquid] #441747
08/18/09 11:17 AM
08/18/09 11:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The bell that is in my son's Dart is most certainly a passenger car part and IS a 69 and IS iron, but I don't know the casting number. It is for the 143-tooth flywheel and 18-spline trans. I couldn't tell you what came on the six pack cars, though.
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: Jim_Lusk] #441748
08/18/09 11:31 AM
08/18/09 11:31 AM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
http://www.mymopar.com/bellhousingcastnumb.htm
Look here.
Bookmark this site for future reference.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: mcoderoadrunner] #441749
08/18/09 12:12 PM
08/18/09 12:12 PM
The bell housing part number in my '69 383 RR is #2892626 (11" cast iron). This is a one year part number and was used for 383, 440 B body cars. Not sure if the 440/6 or hemi used a different bell housing or not.
1968 part number for the B/RB 11" cast iron BH was, #2892262.
If I remember correctly, these two bell housings are identical except for the part number.
Re: need help with P/N for 69 440 Cast Iron Bell Housing #441750
08/18/09 02:18 PM
08/18/09 02:18 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The casting number you need is the 2892626. Part number and casting numbers are NOT the same. 68 bell casting number 2892262 only has the 4-speed pattern, 69 bell has the 3 and 4-speed pattern. You can see the difference when bolted in the car.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: need help with P/N for 69 440 Cast Iron Bell Housing [Re: 64dodge572] #441751
08/19/09 12:00 PM
08/19/09 12:00 PM
Good info!
I have interchanged those bell housings on '68-69 B bodies multiple times over the years and never realized the #262 missing the 3-speed bolt pattern.
Sorry about the "part" "casting" number issue. I knew those where the numbers.
#2892262:
#2892626:
