Re: need help with P/N for 69 440 Cast Iron Bell Housing
[Re: mcoderoadrunner]
#441746
08/18/09 11:10 AM
08/18/09 11:10 AM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
I need helpl with the cast iron bell housing part number for a 1969.5 A12 4 speed car.
They do exist. I had one, was for 143 tooth flywheel. Traded it off and can't find the part#. It's online, just do a search.
[Re: moparsquid]
#441747
08/18/09 11:17 AM
08/18/09 11:17 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I was told that cars had alluminium and trucks had iron?.
The bell that is in my son's Dart is most certainly a passenger car part and IS a 69 and IS iron, but I don't know the casting number. It is for the 143-tooth flywheel and 18-spline trans. I couldn't tell you what came on the six pack cars, though.
#441749
08/18/09 12:12 PM
08/18/09 12:12 PM
The bell housing part number in my '69 383 RR is #2892626 (11" cast iron). This is a one year part number and was used for 383, 440 B body cars. Not sure if the 440/6 or hemi used a different bell housing or not.
1968 part number for the B/RB 11" cast iron BH was, #2892262.
If I remember correctly, these two bell housings are identical except for the part number.
#441750
08/18/09 02:18 PM
08/18/09 02:18 PM
Posts: 4,285 Ohio
64dodge572
Ohio
The casting number you need is the 2892626. Part number and casting numbers are NOT the same. 68 bell casting number 2892262 only has the 4-speed pattern, 69 bell has the 3 and 4-speed pattern. You can see the difference when bolted in the car.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#441751
08/19/09 12:00 PM
08/19/09 12:00 PM
Good info! I have interchanged those bell housings on '68-69 B bodies multiple times over the years and never realized the #262 missing the 3-speed bolt pattern. Sorry about the "part" "casting" number issue. I knew those where the numbers. #2892262: #2892626:
