Using Dual Field Alt in a 69 and earlier car? #441736
08/18/09 12:28 AM
08/18/09 12:28 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
What method do you use to use the later altenator in the earlier cars? I have been told to remove one of the plastic washers on one of the field terminals with a metal one and ground it to the case, is this correct?
Re: Using Dual Field Alt in a 69 and earlier car? [Re: SCATPK] #441737
08/18/09 01:20 AM
08/18/09 01:20 AM
A short jumper wire from the 2nd field terminal to one of the (3) thin case bolts will work or pirate a grounded brush holder from an earlier alt or as you said eyeball it & change what you have to to make the brush holder grounded
Re: Using Dual Field Alt in a 69 and earlier car? [Re: RapidRobert] #441738
08/18/09 02:32 AM
08/18/09 02:32 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
1. There's but a single field - it's an isolated field alternator. Splitting hairs notwithstanding...
2. If you ground out one of the terminals internally (as opposed to making the ground an externally visible jumper), please, Please, PLEASE do something with the now grounded spade to render it unusable so that there will be no doubt that something different is going on internally. This is not just for you to remember to which spade the regulator's wire gets connected. It's also to save the next shmoe who might unknowingly find that alternator on his best friend's 1969 Super Bee, and melt some wires. DAMHIK.
Down to just a blue car now.
Re: Using Dual Field Alt in a 69 and earlier car? [Re: SCATPK] #441739
08/18/09 06:25 AM
08/18/09 06:25 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
Upgrade the wiring harness and use it to it's full potential with the 70up volt reg.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Using Dual Field Alt in a 69 and earlier car? [Re: BrianShaughnessy] #441740
08/18/09 07:49 AM
08/18/09 07:49 AM
scratchnfotraction Offline
myself,I would go with the single wire alt that came on it,then upgrade the points style VR with a soild state replacement they have for them
made a world of diff with the 68 Dart,fixed the discharge at idle with the light on,and the amp gauge stop jumping around and was steady across the gauge sweep after that
uping the amps is not a good thing on the older sytem like that,imo
unless you bypass the amp gauge and up the wire to carry the extra juice you will have with a newer alt
Re: Using Dual Field Alt in a 69 and earlier car? [Re: SCATPK] #441741
08/18/09 11:01 AM
08/18/09 11:01 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Depends on what you mean by "later" model alt. This is a 120 amp denso from a 2001 Ram van, $13 at my local pick-n-pull on 1/2 price day along with a 70/later electonic voltage regulator ($12). Simple to make mounts and simple to wire. Feed goes to hot stud/remote mount battery, sensor wire goes to hot @ starter relay where I also pull power for all my relays. Very inexspensive and works perfectly.
Re: Using Dual Field Alt in a 69 and earlier car? [Re: Bill MeLater] #441742
08/18/09 11:49 AM
08/18/09 11:49 AM
Az
Crizila Offline
Crizila  Offline
Az
and I've got 2 ( single groove and double groove )75 ampers for sale at a real good price under for sale, engines, small blocks. E-mail me if you want pics.
Fastest 300
Re: Using Dual Field Alt in a 69 and earlier car? [Re: Crizila] #441743
08/18/09 03:52 PM
08/18/09 03:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I assume you want to put a dual field alt on your GTX's single field alt ?? Do you want to update to the newer style electronic regulator ?? It is so simple to do but we need to know if you want to stay with the old mechical type regulator or the newer (70's & later) electronic regulator ? Ron
