Burnout - slippin to the left #441058
08/17/09 05:07 PM
08/17/09 05:07 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
This last weekend at Pacific, I couldnt get the Duster to do a straight line burnout.. The car started slippin to the left side and I could either abort the burnout or do a 180...
As a result, the tires never got hot and I attribute that to the spinning at the line problem... So is there is a list of things I should look at to prevent this from happening in the future?
For the record, 73 Duster street/strip, 727, 8 3/4 sure grip. 275-60 MT drag radials, leaf springs with Cal-tracks set at the lower hole..
Re: Burnout - slippin to the left [Re: Jeepmon] #441059
08/17/09 05:25 PM
08/17/09 05:25 PM
owt west
Thread Ender1 Offline
owt west
Make sure tire pressure is even? also make sure both tires are completly wet.
Re: Burnout - slippin to the left [Re: Thread Ender1] #441060
08/17/09 05:27 PM
08/17/09 05:27 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Both tires were at 17 psi in the staging lanes and the waterbox looked equally wet on both sides.
Re: Burnout - slippin to the left [Re: Jeepmon] #441061
08/17/09 05:30 PM
08/17/09 05:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More RPM....
Re: Burnout - slippin to the left [Re: Jeepmon] #441062
08/17/09 05:31 PM
08/17/09 05:31 PM
add a little preload to the left side or take some out on the right side.
Re: Burnout - slippin to the left [Re: Al_Alguire] #441063
08/17/09 05:31 PM
08/17/09 05:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
Posi unit could be on the fritz, I had some burnout issues as well this weekend.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Burnout - slippin to the left [Re: Al_Alguire] #441064
08/17/09 05:40 PM
08/17/09 05:40 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
More RPM....
Let me ask you this.. would moving to the top hole on the Cal-tracks help to prevent spinning at the line?
two things.. First, I'm not ruling anything out and I too thought about one tire slipping more than the other.. but the unit is fairly new... so maybe, but probably not..
Next, after the 1st run on Saturday, I watch the other cars in the box, it seemed like about 1 in every 12 cars slipped to the left also.. Is there something wrong with "YOUR" track?? lol
Re: Burnout - slippin to the left [Re: Jeepmon] #441065
08/17/09 05:43 PM
08/17/09 05:43 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I've seen A LOT OF CARS go sideways in the box! Why didn't you just pull in crooked to compensate?? haha!
Re: Burnout - slippin to the left [Re: ChrisJohnston669] #441066
08/17/09 05:48 PM
08/17/09 05:48 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
We have a track here that is the same way. You have to really get up on the tires quick to keep it from going sideways. Try staggering yourself to the left or right a bit in the waterbox this usually helps if the problem is being caused by ruts in the waterbox from all of the burnouts.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Burnout - slippin to the left [Re: Irun5snd8th] #441067
08/17/09 05:53 PM
08/17/09 05:53 PM
Renton Washington
Renton Washington
I've made over 100 passes this season alone at said track... my car goes straight 95% of the time in the box.
-Dustin
Re: Burnout - slippin to the left [Re: Triple Threat] #441068
08/17/09 06:00 PM
08/17/09 06:00 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
at said track...
LOL.. that was a clever way to side step the pot stirrin... LOL
Seriously.. it was really good seeing you and your brother again... You guys planning on MATs 2010?
Re: Burnout - slippin to the left [Re: Jeepmon] #441069
08/17/09 06:04 PM
08/17/09 06:04 PM
Renton Washington
Renton Washington
Hopefully with the cars this time. All depends on if and where I can find a job.
-Dustin
Re: Burnout - slippin to the left [Re: Jeepmon] #441070
08/17/09 06:10 PM
08/17/09 06:10 PM
More RPM....
if your car is 11.00 or slower, caltracs should be in the top hole but thats not your problem with going sideways.
do this get someone same weight as you, get him to sit in the car and take out all preload and have a little airgap on drivers side and have bar just barely touching on passenger side. set your shocks on #5.
bet your sideways problem goes away.
Re: Burnout - slippin to the left [Re: Jeepmon] #441071
08/17/09 06:33 PM
08/17/09 06:33 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Time to scale the car and/or check the posi unit.
Re: Burnout - slippin to the left [Re: BobR] #441072
08/17/09 08:02 PM
08/17/09 08:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most of the time, when a car won't stay straight on the burnout, is lack of wheel speed. Get after it. Get it up on the tire quick and hard, keep the rpms up and get it in high gear.
Monte
Re: Burnout - slippin to the left [Re: Monte_Smith] #441073
08/18/09 11:01 AM
08/18/09 11:01 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More RPM I already assume you are doing a burnout in High Gear..Like Monte said wheelspeed will keep the car straight. Wheelspees is also what gets the tire hot.
Re: Burnout - slippin to the left [Re: Al_Alguire] #441074
08/18/09 11:32 AM
08/18/09 11:32 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Naw, I was lazidazical and really didnt hit the burnout hard... (looking for an excuse here) ..... I was saving my motor for the run... yeah that's it
Thanks guys, I'm sure the lack of wheel speed was the problem and it wont happen again...
Re: Burnout - slippin to the left #441075
08/18/09 12:02 PM
08/18/09 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DO NOT change pre load for the water box... that is
for the track itself.... get up on the tire speed more.
Alot of the burnout boxes arent anywhere near level
so that will be part of your problem
